Kenmore 22642 Top Load Washer
Problem for Kenmore 22642 Top Load Washer
Spin cycle wont work. water drains but clothes are
By rob_clark10 on Oct 18, 2009
spin cycle wont work. water drains but clothes are wet
Solution #1
posted on Oct 18, 2009
Not Rated)
oldguy5
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 95%, 121 votes
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
Since the washer will drain, the lid switch and timer should be OK.
This is the Whirlpool PDF on installation and maintenance of direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase and the "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
You can also see this site for removing the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
OR
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 22642 Top Load Washer
Questions and Unsolved Problems for Kenmore 22642 Top Load Washer
Do you recommend Kenmore 22642 Top Load Washer?
Answer
Answer
kenmore wont drain or spin and knob is making clicking sounds when i attempt to turn it on
Answer
Does not pump out sudds and wash have machine Part No. 8280539 white & FSP # 8280541 Looks... (More)
Answer
...and the is now an electrical odor as if the motor is being strained...we just bought a set and... (More)
Answer
i just finished replacing the belt but i need to replaced the oil that leaked when i was replacing... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 22642 Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
