Question about Bosch 24 in. SHU43 Built-in Dishwasher
Wont start I've had the washer for many years with minimal problem. Yesterday when I closed the door no light went on and the washer would not start.  After 20 minutes or so it suddenly went on and worked fine.  I thought that it might have not completed its last cycle. Today, however, I had the same problem and it's been over an hour and still hasn't started. (I checked the circuit breaker and it's fine)
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Give it a firm push over the door latch once you've closed the door..it might be the door switch not activating. oops.... first and formost isolate from power for 5-10mins and try
Posted on Jan 03, 2008
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
417 front loader washer - door doesn't register as closed, washer won't start all lights are lit except "door locked" of course I"ve tried to close door fully, unplugged, etc. but no go
The door lock/latch mechanism has failed.
Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 07, 2009 | Kenmore Washing Machines
Washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
May 28, 2009 | Bosch Washing Machines
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door wont lock
to test if there is a fault on your interlock you can close the door now with your hand bang it on the front of the washer were the door hits the catch most cases if it faulty than the washer will start it will then need replacing only thing you can do if faulty m8
Sep 22, 2007 | Hotpoint WMA64 Front Load Washer
Kenmore Elite problem
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Bosch 24 in. SHU43 Built-in Dishwasher Logo
278 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
