When I go to start and choose shut down, the computer will shut down wait 5 seconds and then restart again. I have to push the power button to shut it off completely. I have looked in bios, but see nothing obvious. Any ideas on what this is anyone?
Richard
followed the M/S solution to no avail. First shut down stopped at the blue error screen, then went back to the reboot.followed the M/S solution to no avail. First shut down stopped at the blue error screen, then went back to the reboot.
You can't post conmments that contain an email address.
Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
Choose "Menu" again from within the Settings menu. This displays a different menu than before.
Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
Wait while your Kindle restarts.
E-Reader Factory Reset
Press your Kindle's Menu button. Select "Settings" from the menu.
Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
Hold the Power button down for three to five seconds. A Shutdown window appears.
Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
Press the Power button to turn the device on again.
Fire Hard Reset
Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
Tap the "Settings" option and select "Device."
Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Instead of going to the start menu, choosing shutdown,
then waiting for the computer to shut all the programs down, you can create
a shortcut on the desktop to do it quickly. You can create a shutdown,
restart, or a logoff icon on your desktop which will work a lot quicker than
using the usual buttons in the start menu. Here's how to create a shutdown shortcut on your desktop
1. Go to your blank desktop 2. Right click on a blank space and a menu will appear 3. Choose New from the menu 4. Then choose Shortcut 5. Where it says type the location of the item type in shutdown.exe -s 6. Then press next 7. Now enter a name for your icon. Mine is called SHUTDOWN NOW 8. Press next 9. The Shutdown shortcut will be on your desktop
Different combination you can type in when creating a shortcut to shutdown, restart, or logoff.
Shutdown.exe -s
Shutsdown your computer in 30 seconds and will close all programs and ask you to save all work.
shutdown.exe -r Restarts your computer in 30 seconds.
shutdown.exe -l This one will logoff your computer back to the welcome screen where you will need to login again.
shutdown.exe -s -t 1 Shutsdown your computer in one second. the -t 1 tells it how long to wait. (one second in this case) You can put -t 10 or even -t 1120.
shutdown.exe -s -t 15 -c "Goodbye you idiot" This is my favorite code. It will shutdown in 15 seconds and have a message in the box saying "Goodbye you idiot" The -c "bla bla bla" stands for a comment.
Notes:
* to stop the computer from shutting down type shutdown /a into the run box located in the start menu.. * -f will force everything to close immediately without asking to save anything.
(1) You can try ctrl-alt-del buttons on keyboard press all @ same time select (use arrow keys) to move to restart press enter on keyboard or (2) hold power button for 6 seconds it will shut down then wait 3 seconds push start button as normal should re-boot Hope this helps
I assume it is not shutting down. Do a complete reset, unplug computer from wall push power button in for 3-5 seconds, then plug it in and restart the machine. Then let it complete the boot up process then go to start and shut it down again see if it shuts down now. Thanks for the question hope this assists you. John
Please hard push the power button and wait for its shutdown,
after shutdown Please restart the PC it will work, and don't close the screen after your work just shut down and wait for it completely off.
