Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
Hi can you please help me
I have just bought the new motherboard and cpu ram,etc but i am strugging to connect my old cases wires to the board i cant find where they must go ?can you help
    Sergeant:
    Champion:
  • 243 Answers
Details should be in the user manual
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Manual&MenuID=1&LanID=0
Posted on Dec 29, 2007
I just bought a new motherboard; basically new everything, well on my old motherboard there was a CPU and on this newer better motherboard there is not a CPU. Do I need to got one? What is a CPU exactly?
first, make sure that the new mother board support the old Processors, ask the M.Board supplier about it (or google it) , and make sure you know the old processors type.If you wasn't really sure, just remove the old Processor from old M.Board, then check for the ID (such as Pentium 4, Pentium D, etc ) on top of the processor.
If the new M.Board support the Processors, then you can re use the old processors, if don't, then you don't have a choice, buy the new one that match with the new M.Board specifications.
Hope you understand.
Feb 22, 2010 | Office Equipment & Supplies
What kind of mother boards can I use to replace my old one in my gateway E1800 . Also will i need to replace the CPU? (to get more speed)
Almost any AT style board will work in that case. Be sure the new board has the outputs located where they will align with the holes punched in the back of the case or you won't be able to attach your keyboard, monitor, mouse, etc. which will necessitate the purchase of a new case.
Yes, you will need to replace your CPU and your RAM. The CPU is the engine for your computer - bigger, faster processor = more speed. More RAM = more speed! It's like driving a Volkswagen Beetle on your local street (your old CPU and RAM) and a HumVee on the Interstate (newer CPU and RAM.) You will probably also have to replace the power supply to accommodate the increased horsepower requirements of the new parts.
Jan 04, 2010 | Gateway E 1800 (1006023-1) PC Desktop
Looking to replace motherboard on a hp pavillion 7935. Please advice options
Best option is to junk the case, psu and board. Get a new case and psu, install a new board into it with up to date ram and cpu.. Much easier to replace parts (psu etc) and may even be cheaper then the HP stuff..
Oct 30, 2009 | HP Computers & Internet
CPU Problems
What can also give the same symptoms as a doa cpu is bad ram. About the only difference is that you usually get a post code with a cpu problem and absolutley nothing with ram.
About the only way to check a cpu is to swap it out. They are not that expensive compared to a new pc unless you want an excuse to upgrade ;-]
Ram is checked by swapping it out or just removing and checking one stick at a time. Sometimes they just need to be reseated and away it goes.
Also check the power supply. If it has overheated or dired etc nothing will work.
Once you have checked out those three you will know if it is worth fixing or junking.
Sep 11, 2009 | E-Machines eMachines Desktop PC
Can I upgrade a dell 900mhz p3 processor
Not really [ only possible might be to a faster P3 cpu]. Those motherboards are so old it would be cheaper to just buy a new system as Dell cases & power supplies, etc for that old a computer are all proprietary and would take major modification to upgrade to a new motherboard, ram, cpu and such. Hope this helps.
Jul 17, 2009 | Dell (6d514), 900 MHz Processor
PC Chips M848A dead, no screen output or blips
I had the same problem. I bought the M848A from Newegg in an attempt to save my trusty Athlon 2600+ CPU and a fancy Raedon 512mb AGP card which I salvaged out of my old broken down system. I thought it would be a good time to update the RAM so I bought 2 gigs of OCZ 3200 DDR400 to go with.
Problems:
(1) First the damn thing wouldn't boot past the post screen. It would simply cycle thru post over and over. Fixed: The microsoft XPpro operating system was corrupt. The new board hated the old configs from the previous system. After trying (and failing) a os repair, I ended up simply doing a clean intall with great results. Board was stable worked great for a week. Only had one glitch...
(2) The board would only recognize and post ONE of the 2 gigs of ram I bought. I raided all the CMOS settings, and downloaded all the user manuals I could get a hold of and found no answers to this curious problem. On a whim, I opened the case and switched their locations back and forth which led me to...
(3) Lights on, no one home. All the lights came on... power, HDD, cd drives... all the fans worked: case, CPU, graphics card... but the screen would remain blank/unpowered and no post menu would come up. Seemed like it wanted to work, but simply stopped short of booting up. THIS WAS YOUR PROBLEM?!?? On a hunch, (more an angry impulse) I reached over and popped an old Mushkin Technologies (PC 3200 400DDR) 512mb out of my old dead mobo and slammed it solo in the primary memory slot. Bingo. Fired right up.
The board appears to be testy with its RAM... If it fails its initial memory test, it will not post. The screen will not come on. I'm not 100% certain this is the final solution to the problem... I'm still playing with it. My questions now are.... do I have dead RAM? Chip compatibility issues? Perhaps the PC Chips support techs on their website have some practical advice on this issue. I'll keep you posted if you like.
Dec 26, 2008 | PC Chips M848ALU Motherboard
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
Hp motherboard startup problem!!
hmmm my sussgestion in yourr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS (power supply to the board), Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch/Listen carefully:
Case 1: if you can hear a long beep, then your CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch/Listen carefully.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
For your help here is picture of general moherboard with connection details. 86c6af2.jpg
Thanks
Iqbal
Mar 19, 2008 | HP Compaq Motherboard
New Motherboard for Sony VAIO-RX550
I just bought the same box, mostly for the case, power supply, etc, to use as a small server.
Three ARE 2 ram slots, but this motherborad IS limited to 512mb total. And it uses SDRAMM PC133 or 100, not SO DIMM - incompatible. PC133 SDRAM 512 is $9 (btw, installing in pairs not required on DDR SDRAM) and even if your existing is 256 & an empty slot, buying another 256 may not work, sometimes brands are incompatible. Just get the 512.
However, replacing the motherboard is your ONE chance to change lots of things at once which may be the best choice at this point. Physical size ("form factor"), CPU socket, memory type & price, graphics connections (AGP, PCIe, or built in) are key factors.
1\ the case fits a "Mini ATX" mother board (mATX). The majority of accessories use PCI lots - sound, LAN, etc. and every mother board will have 3 or more PCI slots. Probably don't need modem anymore.
2\ what CPU does it support. The original P4 1.5GHz cpu is normally a primary expense, but today your P4 Socket 478 is worth $8 (pricewatch.com) brand new. This means buying a motherboard-cpu combo may make sense. While you're at it, get more & faster memory and you'll think it's a new PC for less the $100 unless you go all out.
3\ what type & how much memory it handles & how much you have. Existing PC133 SDRAM is old & slow, about 8x faster SDRAM ddr2-800 pc2-6400 2GB is only $24 and 2GB is about the minimum today. (btw, DDR2 - notice the 2 - IS installed as a pair.) DDR is far from current, but plenty fast and very cheap, just need to balance the memory-motherboard-cpu combo.
4\ if not playing games, the video card is old but ok. It connects via the largely discarded AGP slot. So in looking at a motherboard combo, either with an AGP slot or on-board video is desirable.
Mar 11, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
ASUS M2N-E MBOB
remove the processor and ram from the mother board. now connect the smps to the motherboard and on the motherboard. if the problem persists again then u have the problem with the motherboard. if the board gets on then insert the cpu and on the board if this dosent work then their is problem with the cpu. this applies to all the motherboards
Sep 27, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
113 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
