Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
The water dispenser is not working but the ice maker is working fine. What could be the problem?
my ice maker dispenses ice, but i can't get water to come out.  I already changed the filter.
  • 2 more comments
  • lgabriel Dec 31, 2007
    An absolute life saver!  I tried this and after five minutes, I had flowing water!  be careful not to touch the back of the fridge after you do this, though.. I singed my hand a little.
    My fiance thought I was crazy for taking a blow dryer into the refrigerator but is just as happy as I am not to dish out for repair costs.  I immediately called to cancel the appointment once the water was flowing (my manual said call for service, too.  I would've been irked if I paid $100 for someone to "defrost" a tube).
    Thanks again, and Happy New Year!
  • Frybaby Feb 07, 2009
    ice maker and water dispenser not working.  I've already turned refrigerator and freezer off for 24 hours, but same problem.  Any ideas?
  • Anonymous Mar 18, 2014
    water not getting into the ice maker
  • Anonymous Mar 29, 2014
    No water is dispensed but water is getting to the ice maker which is good. This model does not have a filter.
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
Where is the tank at? I'm having trouble with my dispenser as well and do not see a water line or a "tank" in my fridge.
Posted on Mar 15, 2008
Brilliant! Thank you so much.
My dispenser was working but not the ice maker. The hair dryer worked in about 5 minutes.
Posted on Jan 25, 2008
  • 319 Answers
It is possible that your water reservoir is frozen. This is located usually behind the lower fridge side drawers. There is a white "tank" that has a water line going to and from. The tank is there to provide "cold" water. I have had mine freeze on several occasions, and the easiest fix for me is to remove the crisper drawers, and use a hair dryer to help melt the ice. It can take several minutes, so remove any food that you don't want to get warm!
Remember to be careful with the hair dryer, as it is an electrical device!
I hope that this works for you. The product manual for my GE refrigerator suggests that you call a repairman!
Posted on Dec 31, 2007
  • 18 Answers
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Posted on Jan 07, 2008
5 Suggested Answers
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
  • 18 Answers
I have the same problem, although mine is intermittent. Apparently it's a problem with the line freezing. For an excellent discussion of the issue, see http://www.askmehelpdesk.com/advice/t-14182.html
Posted on Jan 05, 2008
mine did same thing. What is happening is the Water Line in the freezer door is freezing.
SOLUTION. Leave the freezer door open and turn off the freezer for a night. Be sure to dump out all of your ice cubes too.
In the morning it will work like new. To prevent it from happening again, open the FRIDGE door and use the electronic controls to raise the temperature of the freezer. You had it too cold before...thats why your water line froze in the first place.
Posted on May 02, 2008
GE GSH25JFTA BB water dispenser not working but ice cube maker working fine
Ice maker is working. Water dispenser is not working. I did the initial diagnosis and the water line is not frozen. How do I replace the water valve or is that the right next step?
Jan 05, 2012 | GE GSH25JSTSS Stainless Steel Side by Side...
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
Dec 20, 2007 | Refrigerators
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
1,101 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
BOYNISMO
