Question about Bissell SpotBot Robotic Wet/Dry Vacuum
Spotbot is leaking...
My Spotbot is leaking. I think from either the bottom or side. After I use it there is a big soaked spot on the carpet. The solution is going fast. I use it all the time and have never had problems before....
  • 7 more comments
  • ncfm80 May 18, 2008
    The 1st Spotbot we bought leaked immediately out of the box so we returned it, figuring it was one of those things, and got another one. VERY Happy, worked great-just as expected, until recently.
    A few months ago using the manual mode resulted in a wet spot on the floor and the solution tank emptying quickly.
    More recently the same thing started happening in the "automatic" mode.
    Today it worked for a few minutes then stopped spraying or sucking-up in either mode. Makes "normal"sound for when running, but doesn't do anything but rotate brushes.
  • bethanybm Jun 20, 2008
    Used it twice and it leaks big time. I've had it only a week. Back to the store it goes.
  • sk8355 Feb 07, 2009
    I have loved my SpotBot for about a year and I half now but today it started leaking!! I will try the get the new ducks.
  • jjb13 May 10, 2009
    Two years ago we bought a spot bot. Really works well, but after you are done, it drains onto the floor/carpet from the soap/water dispenser. If you take it out and put the unit away, your fine. So about 6 weeks ago in March2009 we bought another spot bot pet unit. After a couple of uses the same problem. Again remove the soap/water container and the leaking stops. The Book is very clear that you can leave the cleaning despenser in. Good luck. design is flawed. too bad as it really works well.
  • oliviar May 19, 2009
    My spot bot worked well for the first couple of months I had it. I just got a new puppy so the last couple of weeks I've been using it a lot. Not only does it leak now but every time I run it, hose or just setting the bot on the spot, it smells like burning rubber! It's so bad it makes the whole room smell. It was a gift so I can't return it or anything. Any ideas on what could be wrong? Does it need to be cleaned? How do I do that?
  • cath301 Aug 02, 2009
    I have had it for almost a year and I loved it when I first started using it. I have 2 kids so I use it alot. One day I got it out to clean a spill up and started to use it. When I was finished using the manual(hose) setting, I picked the machine up and it left a big spot of water on the floor. Was not happy b/c I love this machine. I don't know if I should return it or get a different machine. Anyone have any suggestions?
  • jswilburn
    jswilburn Apr 08, 2012
    I've had a couple of these - pets, kids - it's the best I've found for both. I, too, have had the leaking problem....as well as most recently - it stopped sucking. I presumed it was b/c I used an unapproved solution in it (made my own oxy-clean solution)...?? Attempts to "unstop" it were unsuccessful. Suction still works...such a shame, though....
  • Martha Feb 18, 2013
    Mine was leaking from the bottom and had no suction. I ordered a new duckbill valve and voila it works like new. Why can't Bissell add something to hold this valve in place properly?
  • husker sewvac
    husker sewvac Aug 23, 2013
    This is due to a flaw in the clean water cap. The rubber creating the seal is either ripped or warped or hardened. You can get a new cap for under 5 dollars almost anywhere and 90% of the time this will cure the issue.
Mine constantly leaked as well but I found that if I remove the container will the solution in it after every use it doesn't leak anymore. I store my container (upright - nozzle face up) under the sink with my other cleaning products and when I need to use the machine I pull it back out, pop it in and clean.
HTH
Posted on Jun 28, 2009
  • husker sewvac
I ordered a duckbill valve from Bissell as I had leaking around the bottom, it was going through solotion like crazy and didn\'t suck up dirty water. I just installed the new valve and it works like new. Bissell should figure out a better way to hold this valve in place.
Posted on Feb 18, 2013
The hose connection inside the machine has probably become detached from all the vibration. I opened up the machine from the bottom (lots of screws to turn and remove), reattached the hose and now my machine works perfectly, no more leaks.
Posted on Aug 07, 2011
I found that our spot bot would leak after three cycles.. If you dump out the dirty tank after each cleaning and carefully and firmly replace the tank [I also remove the clean tank, and set it upright but probably not ness. ] it should work as it is supposed to work. By the way, I love the spot bot it cleans wonderfully!!
Posted on Dec 19, 2009
Mine is several years old and I've used it a lot. Recently I discovered that the floor was wet after I refilled the clean water tank. The plastic gasket on the inside of the clean water tank cap had a small split. Since then, I've made sure that the cap is on extra tight and haven't had a problem since. I leave water in the tank all of the time so that it's ready for the next spill. A new cap can be purchased from many places for $3-$4 dollars but I'm waiting until I need several parts just to make the shipping worth while.
Posted on Jan 12, 2010
I just noticed the same problem with mine.
I looked carefully over the entire machine and found that the plastic lever which snaps over the top of the recovery tank is a bit loose.This cover has to be a tight fit. I discovered a little plastic part on the machine, and under the snap cover to be broken. This is supposed to lock the cover tight against the recovery tank to create the suction needed to extract the water from the floor. Hopefully I can take the machine to a service dept and :HOPE: that bissell has a new and improved replacement part. Otherwise I'll have to get creative and make some ugly modifications.
Posted on Oct 03, 2009
    Problem Solver:
  • 10 Answers
We wound up getting a replacement unit as the "old" one was still within warranty period.
I have found that if the SpotBot is used once or twice there is no problem.
If the unit is used more than twice in a short period it starts to leave wet spots. This leads me to believe that it must always leak within the housing, but remains "contained" and only becomes evident after several successive "cycles" of use.
Bottom line, I believe, is that it should be used as the name suggests - on a spot or two, or one spot twice. Any more than that you should use a larger steamer or shampooer, upright (like the vacuum) style.
Just my thoughts.
Posted on Feb 25, 2009
  • husker sewvac
    Actually you can use these for 8 hours a day if need be. There is just an issue with the clean water side cap.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 38 Answers
I just received and installed a replacement duckbill gasket in the dirty tank because I lost suction/had leaking, and found to be missing the gasket. Leaking now gone, suction minimal though. Normally water sprays into the dirty tank, now it just kinda dribbles, leaving the floor fairly wet.everything else checks ok. I even took the nozzle off the hose and sucked down a couple glasses of hot water, and it worked amazingly well, and flushed hairball from system. Checking vacuum nozzles next...
Posted on May 19, 2010
  • 1 more comment
  • pulsev2 May 19, 2010
    Just installed fresh duckbill gasket. Was missing the original from the dirty tank base. Had leaking, no suction. Now I have no leaking but minimal suction, leaving the floor very damp/wet. Everything else checks ok. Used the hose to **** down a few glasses of hot water and I flushed a hairball from the system, and suction worked excellent. Reconnected hose and ran a cycle and the suction is still lacking. Water normally sprays into the dirty tank, now it just dribbles. Checking vacuum nozzles next. AArrrggh
  • Tho Mas Feb 18, 2018
    Me too....put in a NEW duckbill and I get the water dribble effect. Collected dirty water used to wash and flow down the inside of recovery tank. Now it just sort of dribbles. This happened before when I thought I'd lost the duckbill and had to order a new one. That duckbill also resulted in weak water suction. Fortunately I then found the original which I put back in and got good results. So. I've tried two new duckbills with same results each causing weak vacuuming, water dribble and wet carpet. I'm thinking defective duckbills as in not thick enough to correctly seal between recovery tank and unit.
  • pulsev2 Feb 19, 2018
    I no longer mess with the spotbot at all. Found myself playing games with highly unsanitary pieces too often. Moved onto Rug Doctor. Well worth it. Commercial grade parts!
Either the "duck valve" on the dirty water tank or the clean water tank valve (in the screw top) are leaking. you can buy either or both from bissell for a few bucks.
Posted on Jan 07, 2008
Tip
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
Clean bissell spot bot brush
NONE of these answers apply to the question! The asker referred to the Bissell SPOTBOT, which doesn't have a push handle. I'd like to know how to remove the brush myself. I know how to remove the components but haven't been able to figure out how to remove the mechanism.
Mar 12, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Spot Bot leaking water from reservoir through brushes
make sure that your collection tank is empty and correctly attached. If it is full, it will shoot water on the spot, but not **** it up several times in the cleaning process leaving a large wet puddle bigger than the original spot.
Mar 16, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Leaking rusty water
Ensure the black "duckbill" gasket is mounted on the bottom of the dirty water tank. This gasket is removeable, and resembles a duck bill.
When i purchased mine at Target, new - it was missing the gasket, causing loss of suction. Interestingly it worked for a week or 2 then started leaking. Now, with the gasket in place, it works like a charm.
Gasket is about 2 bucks available from Bissell.
Aug 14, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
It is leaking water from the bottom
I had this problem, and after some research found out I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
I purchased this gasket from Bissell for 1.39 and the suction is night and day. No more leaks. I purchased my SpotBot Bissell new at Target, so I have no idea where the black gasket went.
Jul 07, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Spray does not soak the carpet like it used to.
You probally have a clogged line. Either take it apart yourself and manually unclogg each line (requires a compressor) or take it to a local vac shop and have them do it.
Apr 15, 2009 | Bissell SpotBot Hands-Free Compact Deep...
Bissell spotbot: leaking the dirty water from bottom. I took the bottom plate off and there is a really crappy rubber seal. I think it is leaking from there.
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Sep 07, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Within an Hour my SpotBot stopped working
Some of that water must have gotten inside amd shorted something. If this is less then 1 year, it would be under warranty. It iwll have to be taken apart and checked.
Dec 02, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
9,956 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
