Carrier 38BRC036 Air Conditioner
Problem for Carrier 38BRC036 Air Conditioner
New unit just quit no compressor, no fan, breaker
By frostee24 on Oct 18, 2009
new unit just quit no compressor, no fan, breaker not trip, blower unit working fine
Solution #1
posted on Oct 18, 2009
Not Rated)
jumptrout51
Rank: Guru
Rating: 89%, 1021 votes
Remove the access cover from the outside unit. Find the contactor. It is the part that has the high voltage incoming wires attached. There is a button/bar in the center of the contactor. Use a insulated screwdriver or a wood pencil and push the bar in. If the unit starts you will have to trace the low voltage circuit from the thermostat and air handler to the outside. 24 volts should be present at the low voltage contactor terminals via the defrost board. If you have 24 volts to the defrost board,turn off the outside power, remove the red low voltage wire from the defrost board then reattach it. The board may be tripped on a low voltage fault.
Report back here with your result.
Was this helpful?
Yes
No
Popular Solutions for Carrier 38BRC036 Air
Questions and Unsolved Problems for Carrier 38BRC036 Air
Do you recommend Carrier 38BRC036 Air Conditioner?
Answer
Answer
I have a SHARP AY-a249J system that starts cooling for about 20-30 minutes then the cooling system... (More)
Answer
Answer
My comfort Zone II has stopped displaying the third zone. What could be the problem?
Answer
My dehumidifier runs but does not extract any water.
Answer
Last winter a Repairman came to my home and replaced the control board on my carrier home unit with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Carrier 38BRC036 Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
