It will copy/print but if i put in a pic and hit scan then start. the on/off light flashes then it quits 1 min ltr with no pic scaned
Have you tried to use other application such as camera and scanner wizards. Please try that... If you're able to scan picture then there is nothing wrong with the printer so, you said you uninstall the home center already so try to uninstall and reinstall the .net framework version 2 and then relaunch the software to see what will happen
Well its a solution but you shouldn't have to do it. Having spent several weeks batting e-mails back and forth to Kodak they eventually gave up on me by saying 'it must be your computer' which was pretty unhelpful and also completely wrong.
So in desperation I downloaded a free scanning program called Metadms ver 1.04, installed it and now I'm able to scan using this program, (it does jpgs and pdf). The original Kodak software still works ok for copy and print but still not for scanning. Still at least I have a workround.
I have to say I am most unimpressed by Kodak. I've recently got rid of my Kodak digital camera because it broke twice and they wanted almost as much as the cost of the camera to fix it. Now this bug ridden printer software, which means that as soon as I can I shall be moving over to Epsom/HP/Cannon etc. You think they would realise that so many people are having problems with their products it might be a good idea to spend some time fixing them!
Go to Start>ControlPanel>PrintersAndOtherHardware>ScannersAndCameras>
There Should be an option under "Imaging Tasks" to add the scanner to your network.
Thats what was stopping mine anyway.
Scanner works if I use the printers and faxes, and then select my scanners and cameras button. Don't use the scan button on the easyshare. It shouldn't be that way, but it is.
Bump:...Same here copy OK, print OK, scan color picture OK, Scan color document OK, Black & white document scans very poorly no matter what resolution scan is set. It looks like this would be the easiest task for the scanner...B&W doc...! ?? I'm running XP
Why don't you call to the manufacturer for this printer? Everyone has different error codes and different condition for the problem. try www.kodak.com/go/itg or www.kodak.com/go/support
it will copy/print but if i put in a pic and hit scan then start. the on/off light flashes then it quits 1 min ltr with no pic scaned
Have the same problem? Click Here
Same thing. I tried scanning through the software program and got an error code.
Yes! Same thing is happening with me, Flashing light and then no scanning happens. Someone Please help!
I can't get it to scan, either - using an imac with leopard
I get an "unable to complete scan error code 1-2008 ' message. Contacted Kodak and was told to download Firmware. The download did not help. I am waiting for another answer. ( 5100 model )
will print and copy but it will not scan.
Same problem. If I try to scan, it tries to start, but then it shuts down the software completely. I also can no longer use EasyShare photo software, so all my pictures are unusable at this point. Have been in contact with Kodak and nothing has helped so far. I've upgraded firmware, uninstalled software, reinstalled software etc etc etc.
Same problem....Operating System - Windows Xp Pro......Copy and printig working ....Scanning - unable to complete scanning operation Error Code 1-2007...Upgraded Firmware, uninstalled software, reinstalled ans so on.....KODAK AiO Home Center freezes on screen
same problem with scanner. kodak 5100. have contacted kodak numerous times, removed software, reinstalled, still cannot scan. this is getting infuriating.
got error 1 - 2005 scans but it does not scan when i adjust scanning area. this 5100 sucks. really really sucks.l any one know what to do with this error code ?
Same problem as others. Any solution yet?
I have a Kodak EasyShare 5100 also and have the same problem with scanning and copying a document from the home center. I can print. I get
Error: "Unhandled exception - MSG_opends failed with result 1 and
condition code 5.
Click quit and you get Error Code 1-2036
I have tried removing and installing numerous times. Kodak clear utility also. Even a Kodak Tech called me and no help.
I have also tried to get help from Kodak. Has anyone found an anser to this problem?
Thanks
ccolli
I cannot scan either. I get an error 1 - 2007? print and copy works fine?
I have the same problem too and am wondering whether it might be my USB causing the problem. I think my USB is version 1.1 and not version 2.0. Is this the same for all? If so, then we may have found the solution
will copy and print just fine. will not scan through the resource center or through my pictures. os is xp. spent 2 1/2 hours on phone with tech and repeated everything i had already done-uninstalled, use utility to wipe clean, re-install from cd, repeat then re-install from website, update drivers. she had me trying to uninstall microsoft net 2.0. she said something about a glitch in that so it doesn't allow the scanner to work. the connection wasn't great and i barely understood her. i finally told her to forget it because i was going to to return it.
Found solution. Installed using disk and not online. Scanner works if I use Printer / Scanner Wizard in "My Computer". Yippee!
same story here! no clue what to do
mi esp3 kodak no escanea, tambien llame a kodak pero no pudieron darme una solucion al parecer es un problema de compatibilidad
I am having the same prob on my Kodak ESP 7 guess this is a problem that needs to be addressed. i have tried everything. reinstalled software on computer and firware on the printer
scanner not working at all. everything else is ok. i think kodak made a LEMON. i also get error message 1-2036 and ive done everything the kodak tech told me to do. have removed software 4 times and reinstalled 4 times including direct download. geez my old hp works better than this boat anchor also this is the 5500 model
