Question about RCA Audio Players & Recorders
Why does my RCA MP3 player keep lockingup
Player locks up every so often and then i have to let it rundown and recharge it
My does it also. I have to remove the battery to turn it off.
Posted on Jun 04, 2008
Doesn't start
  • Battery may be depleted. Please recharge.
  • Ensure the keys lock is not activated.
  • Reset the player by pressing and holding Power/Menu for more than 10 seconds.
  • If the player still cannot be turned on after resetting, perform a firmware upgrade to restore it.
Sep 24, 2013 | RCA M4204 MP3 Player
Can not recharge
maybe the usb port have a problem
May 18, 2012 | RCA M4208 MP3 Player
My Opal RCA MP4 player will not play. it keeps
Assuming the lock key on the back of the player is in the unlocked position, it sounds like there is a corrupt firmware file. This should just need a firmware reinstall.
Download the firmware install from the RCA website: http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Follow the on-screen instructions to perform the install.
Be sure to back up any important media before performing this install.
If your computer does not recognize it, press and hold the play button while connecting the device for upwards of 30 seconds.
Nov 20, 2009 | RCA M4204 MP3 Player
It keeps blinking rca and wont play the music
You may have accidentally turned on the 'hold' control. Verify that it is switched off. If so you may need to recharge or change the battery. If neither option is the solution; look for the Player's Reset button. It will be a very tiny hole on the back, side or bottom of the player(usually)near the USB port. Use a the end of a paper clip or other fine point object and press the button/hole. This will restore your player to factory default settings, without deleting your music.
If none of the above work; your last option will be to reformat the player. Refer to your owner's manual or read online at the RCA website.
Feb 20, 2009 | RCA Lyra RD1072 MP3 Player
Turning off
check to see if its locked on the back ,lock button could be stuck or locked'
Dec 15, 2008 | RCA Lyra RD1072 MP3 Player
RCA H125A
That could be a hardware failure - requiring replacement, but go to the RCA website and get the Recovery tool. I'm assuming that you already tried resetting the player. If RCA's methods fail, try this:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
Jul 06, 2008 | RCA Lyra RD2763 MP3 Player
Mp3 player says key locked system shut down
I had this same problem on another RCA player.. with no instructions manual it was hard to figure out what keys locked meant. Then I noticed a little slider on the side of the player, it has a little icon of a pad lock on it. Once I slid this back, the keys lock problem went away and I was able to listen to my music once again.
My best guess of what keys locked means.. you don't want you mp3 player to turn on when you put it in your pocket with your keys, so you change the slider to be locked, when your sit down and your keys are pressing against your on button, the mp3 player will shut off... as we all have experienced in frustration.. saving your battery.
Perhaps RCA should make this slider bright orange so it pops out and does not blend in so much, or they should put it right next to the on button.
Apr 30, 2008 | RCA OPAL M4001 MP3 Player
RCA TH1101 series Mp3
my recording keeps on sayinh too many folders
Jan 02, 2008 | RCA TH1101 MP3 Player
RCA S100 Locked Keys
there is a hold button on the right side of your mp3 that locks it if you switch that off you can get back on your mp3 that should solve your problem
Nov 25, 2007 | RCA OPAL M4001 MP3 Player
Rca opal m4002 mp3 player
How do I delete songs off of my mp3 player?
Oct 09, 2007 | RCA OPAL M4001 MP3 Player
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
