Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlppol Duet HT HF failure despite water pressure.
Are there fixes for this problem. Water pressure is OK.
  • 36 Answers
Check the screens on the fill valves on the washer after disconnecting hoses
Posted on Dec 28, 2007
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet HT washer. Due to the freeze, and burst pipes, we haven't used it for a few days, but got the cold water line fixed. However, when we started the washer, it came up with an F20...
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you do not have the hot water line fixed, then that is where your problem is. The washer looks for water supply on both lines. It will still work, but you will get this error.
Feb 06, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
My front loader is saying error FH ? Do you know
Here's the FH troubleshooting guide
or check out link go to this
http://www.repairclinic.com/0078.asp
WHIRLPOOL
Duet & Duet HT Failure
Code
Condition Check/Repair F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Mar 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does code HF mean?
Or
  • Verify CCU operation
OR use links below to troubleshoot and fix.
http://www.washerhelp.co.uk/diy-repair-help.html
http://www.applianceaid.com/partsmanual.html
http://www.applianceaid.com/ http://www.appliancerepair.net/apnet/
____________________
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The letter f flases
WHIRLPOOL
Code
Or
Jan 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code hf came up on my washer
The HF or FH indicates that No water detected entering machine or Pressure switch trip not detected.
Or
ACTION
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FLASHING HF CODE WILL NOT WASH OR UNLOCK
* Verify there is not a siphon problem
* Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
* Check all hoses for possible leaks
* Verify pressure switch operation
* Verify flow meter operation
* Verify CCU operation
Sep 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I am getting the error coder HF on my washer and no water is going through it Does anyone know what is going on?
Did water enter the machine at all? If so then valves are good and pressure switch may have a problem, open top and check connection to pressure switch and check pressure hose for holes.
if no water entered then valves are at fault, check your water supply connections and try a different temp.
2 causes, if in 30 secs no water was detected entering machine or after 8 mins flow meter measured 10.5 gallons and pressure sw trip not detected.
Apr 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops about half way thru cycle anf error code HF appears
Or
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
210 people viewed this question
Dan Webster
Dan Webster
Sal De
