Question about Whirlpool MH7135XE Microwave Oven
Microwave oven door removal
How mdo you do it on a Whirlpool MH1150XMB?
Because I have an older one, same identical model with a broken door while my newer one has a bad magnetron. The older one works well so I want to replace the door and reinstall it.
Posted on Jan 01, 2008
  • 579 Answers
First you have to tell why you want to remove the door. The door seal is important to keeping the radiation from excaping and is not recommended to fool with it.
Posted on Dec 31, 2007
Are there fuses, how do I get to them
Part description and diagram is here: http://www.appliancepartspros.com/whirlpool-fuse-thrml-w10138793-ap4308182.html
Unable to find a service manual, but here is a link to other documents:https://www.helpowl.com/manuals/Whirlpool/MH1150XMB/133577
May 11, 2015 | Whirlpool MH1150XM Convection/Microwave...
What are the dimension for the whirlpool MH1150xmb-4 mircowave
I can only give dimension in inches.
Width is 29 15/16 Height is16 1/4 Depth is 15 3/8
Jan 29, 2015 | Whirlpool Microwave Ovens
MH1150XMB
It's important that high-current devices like microwaves be on their own dedicated breaker.
I would suspect the 20A fuse and then the oven cavity thermostats, in that order.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components (such as the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Oct 11, 2012 | Whirlpool GH8155XJ Microwave Oven
I just installed a new MH1150XMB and the door is cloudy lookinh. There is a plastic film over the inside of the door, does this need to be removed?
Normally, no. That protects the metal mesh which blocks microwave energy from getting out the door.
Check your owner's manual.
If you do need to replace that clear cover, or any other door parts, etc., you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 25, 2010 | Whirlpool MH1150XMQ Microwave Oven
The guys here gave me good advice and that I probably need a new magnetron for the Whirlpool MH1150XMB-0 (runs but does not heat food). I think I can replace the magnetron but dismantling this hood...
DO NOT!!!!!!!!!!!! undertake this job unless you have a pair of discharge leads and you know how to discharge this appliance the capacitor holds a charge large enough to kill you for about a month
Sep 28, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave Whirlpool Model: MH1150XMB The keypad numbers 1,2,3,4and 5 suddenly stopped working. any suggestions?
you'll have to buy a new control pad, or if you can solder you may take display out and see if the connections are broke to those buttons and solder them back.
Sep 16, 2009 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool MH1150XMB-0 runs but does not heat food
If the housing of the unit isn't too difficult to remove (normally 3-5 Phillips screws around the rear edge), with the unit unplugged of course, check for a user replaceable fuse inside. The magnetron is separately fused and fuses can fail due to metal fatigue. It will be high amperage; 10-20 amperes and many hardware stores will have them. BTW, there is no residual radiation from a magnetron that isn't operating.
Aug 18, 2009 | Whirlpool MH1150XM Convection/Microwave...
MICROWAVE WONT HEAT
the lock on the door could be loose so the microwave light will turn on but it wont heat u should press on the door or buy a new one emai me at chattarbox24_7@yahoo.com
Jul 21, 2009 | Microwave Ovens
Whirlpool MH1150XMB
Driver turntable or turntable motor needs to be replace
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Aug 24, 2008 | Whirlpool MH7135XE Microwave Oven
Whirlpool Microwave excessive grease build up
First you should be sure the ventilation is correct through the oven.
If you don't feel air through the vents when it's running, that needs to be addressed.
Also, it's important to wipe off the interior surfaces whenever moisture seems to be accumulating.
Also, it's recommended to leave the door open a few minutes after cooking to allow it to dry.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 14, 2008 | Microwave Ovens
Whirlpool MH7135XE Microwave Oven Logo
191 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
