Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Mitsubishi WD-52327 Picture flickers and goes blue
I have a strange issue with my Mitsubishi WD-52327 rear projection TV. After 15 - 60 minutes of use, the picture flickers and goes to a solid blue screen. If I turn the TV off and wait for the fan to stop, I can regain the picture by turning it back on. Any ideas on what the problem could be?
Thanks in advance!
  • YeshuaMelech Jan 24, 2008
    After more tinkering, I found that you were right. The video cable from the tuner to the TV had deteriorated and by replacing it the problem is gone! Thanks for the advice!
  • 42 Answers
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Posted on Jan 24, 2008
What is the cause tv turns on about half hour turns off red flash
most likely the lamp. pt# 915P020010
Recommend Phillips, OSRAM, or Mitsubishi original, as others may not work at all or have a very short life.
https://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-52327
Mar 17, 2015 | Mitsubishi WD-52327 52" Rear Projection...
I have to change the lamp on my mitsubishi dlp tv. where is the lamp located?
Here is a link to the owners manual for lamp cartridge replacement. Specifically go to page 65 for instructions. Good Luck : )
http://support.mitsubishi-tv.com/files/oguide/WD-52327.pdf
Jul 26, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Do not remember code to unlock tv its a Mitsubishi WD-52327 52 is there a way to reset it
Thanks for visiting FixYa;
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds.
If that does not work unplug TV for 5 minutes, or you have bad buttons on your control panel. You can disconnect the board from the front of the TV. Take off speaker grills, remove cover(5-6 scews), unplug cable to control board. The TV will work with remote but not manually.
Good luck, Big Irish.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
How to clean Mitsubishi TV WD-52327 fliter
Remove the 2 screws in the access panel on the left rear side of the tv. You will see the filter behind it. Rinse the filter in warm water until clean. Lay it flat on a paper towel and fold the other half of the paper towel over it. Press gently on the towel to soak up most of the water, and install it in the tv.
Oct 10, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Sound no picture
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jul 02, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
285 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
