Question about Hubbell Network splitter
Phone jack I have a phone jack that quits working when I hook a modem direct or split to with the phone and modem.
    Champion:
  • 217 Answers
If you can see the pins in the jack, are they corroded? Also, is the phone cord new? You'll want to try a different phone jack if you have one available.
Posted on Jan 28, 2008
Trying to connect fax with my optimum (which is a triple play package) I also have wireless. The Wall jack cord is going directly into the modem. How do I connect the fax?
Your Optimum modem is acting the same as the phone company's input line to your home. The cord that goes from it to the wall jack is actually powering up all wall jacks it the home. You can:
  • Use any available wall jack in the home to cable up to the fax.
  • Split the output signal from the Optimum and connect to the splitter (may not work).
  • Run the Modem output to the LINE connection of the fax, and the EXT output of the fax to the wall jack (may not work)
Jun 28, 2015 | Office Equipment & Supplies
Could you tell me how to connect the fax telephone and modem please
You need to plug in the phone a phone cord to the jack provided to a second (or split) home phone jack. Download the drivers if necessary, but it should work right away. I assume the computer is already attached.
Mar 05, 2015 | HP Officejet 5740 e AiO Printer
Setup poster
If you have a phone modem, it usually has two jacks, one goes to the wall and the other is for a phone. There will be little icons that will represent a wall jack or phone.
If all you see is one large "jack", that may be the ethernet or NIC jack; you might not have a modem, as many newer computers don't come with a phone modem.
It's cheap enough to buy a phone modem that plugs into a USB port, or to get an internal modem.
With the model number, someone might give a link to a picture showing the ports available, and their titles.
Oct 29, 2013 | eMachines Computers & Internet
All three were working but 2 of them quit suddenly and say "Check Tel Line". The one that still works is plugged directly into modem. The 2 that say check tel line will work if i plug them into modem just...
This phone system should only have one physical phone jack connection as all the handsets are wireless. It sounds like you may be getting your phone service via your Internet Service Provider. It would help to know how you are connecting your home telephone wiring to your equipment.
Oct 29, 2013 | Uniden DECT1560-3 DECT 6.0 Expandable...
Modem
Your connections are screwed up. Call your cable company for help in getting you straightened out.
Apr 24, 2017 | Telebit Refurbished OPEN BOX EXTERNAL...
Trying to hook up my xbox to the internet, I moved everything out of the spare bedroom to the living room. problem is the nearest phone jack to hook up the cable to the modem is in the kitchen, or do I...
Hello noah757702
In order to connect to Xbox 360 your modem would need both cable and phone jack, first ethernet cable connected from Xbox 360 to the modem and modem in turn should be connected to the phone jack to complete the connectivity set up, let me know if you need more info on this
Nov 17, 2009 | Video Game Consoles & Games
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
How do I hook up my acer aspire to my existing phone line modem? I know there is an ethernet cable that goes to the Aspire but I need something that fits the phone jack also. Is there an adapter?
Hello, I regret to inform you that you cannot connect a phone line directly into an ethernet port. The phone line is an analog signal and requires a modem to convert it to a digital signal the computer can understand.
+++++Please remember to leave feedback to help keep this site free+++++
Sep 02, 2009 | Acer Aspire One Netbook 8.9" Notebook
Hooking up mx310 all in one
The phone line should plug directly into the Line plug on the DSL modem and the all-in-one should plug into the Phone plug next to it. If you need to split the line do it AFTER the line comes out of the Phone plug.
Feb 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Brother mcf-440cn
Jacki
 Must have DSL filter attached before fax, not sure how you are saying you have it setup, but phone line should come from wall then to filter then to fax socket marked line, phone should be hooked to socket on fax marked EXT, if you dont have dedicated fax line then fax number will be same as phone no.
If you have Adsl then there will be a lead from wall that splits into two, one goes to your modem (ADSL) and the other marke phone or line needs to go to fax socket marked LINE
Oct 21, 2007 | Office Equipment & Supplies
Hubbell Network splitter Logo
64 people viewed this question
Top Hubbell Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Hubbell Computer and Internet Expert? Answer questions, earn points and help others
