Question about Philips PM435S Remote Control
Philips universal remote codes
Need codes for remote
  • 3 more comments
  • Anonymous Feb 13, 2008
  • bhnt May 12, 2008
    I have a Westinghouse Model: SK-32H240S flat panel TV. None of Westinghouse codes work. I also tried White Westinghouse codes and none of them worked. I used the TV setting and a couple of the codes would not go in. On those two codes all it would do was blink several times after entering those codes. I also scanned all codes and no luck.
  • Anonymous Mar 22, 2009
    NEED THE CODES OR THE PHILLIPS
  • misterfix500 May 11, 2010
    BEST CODES ARE HERE - http://tinyurl.com/laqgw9
    All FREE :-)
  • boots2009 May 11, 2010
    === The Solution For You ===
    Get those codes FREE here!
    (There are others like this, but they are not always free).
  • 4 Answers
Here are the 4-digit codes for my 4 device Philips Universal Remote. It is in pdf format. I have also upload the manual so you can punch forward features, if needed. See the comments at this link. ====>
http://tv.manualsonline.com/ex/thread/view/idThread/549512#comments
Posted on Sep 10, 2008
The solution provides only the 3 digit codes. This may have been for a previous version of the remote. However, the new remote uses 4 digit codes. Adding a 0 in front is not the fix.
Posted on May 17, 2008
K your web site has no free codes for remotes on it thanks for waisting my time asshloes
Posted on Apr 07, 2008
Thank loser
Posted on Apr 03, 2008
  • 689 Answers
I have the link for you to get all supported codes
http://www.geocities.com/aviorix/pm435.pdf
Good Luck, Happy New Year
Posted on Jan 02, 2008
5 Suggested Answers
  • 5 Answers
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Posted on Jul 17, 2009
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
IrishDruid
  • 2712 Answers
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing the following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
SOURCE: i have a philips universal remote code-cl043 and
I just move and lost my code sheet for my phillips universal control is there some where i can get some codes,i have a emmerson television thanks.
Posted on Oct 02, 2010
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
I need code for philip s remote for a sayno ty
Philips rca universal remote codes sayno vcr dvd combo ...
www.fixya.com > ... > Remote Controls
Universal Philips Magnavox remote for a Sanyodvd vcr combo ? I have a cableremote and need to program my Magnavox vcr/dvd combo into it i have 2 dvds ...
How to Reprogram a Philips Universal Remote Controller ...
science.opposingviews.com > Computers
Dec 21, 2015 | Philips Televison & Video
I need a code for my universal remote from Philips. My TV is JVC. That's the code that i need. Please help me......
I need a code for my universal remote from Philips. My TV is APEX. That's the code that i need. Please help me......
Nov 30, 2009 | Philips Universal PH301S Remote Control
Need codes for a philips universal remote for a
http://www.universal-remote.net/philipsmagnavox.html
Please go for the above code
Rate here Please !
Sep 05, 2009 | Philips Universal PH301S Remote Control
Philips pm 335 universal control
Go to www.remotes.com If they dont have it no one will!
Please rate this response and help keep this area FREE!
Jan 23, 2009 | Televison & Video
I lost my remote codes for my philips US2-PM435S
Lost my remote codes for my philips remote. I need the combo codes for a tv, vcr,and dvd.
Apr 20, 2008 | Philips Magnavox Learning Universal Remote
Philips PM435S Remote Control Logo
33,187 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
