Question about Kenmore Oasis HE 27082 Top Load Washer
GE WWA8310G The dial for starting a wash cycle is very loose and hangs a bit. It just spins around when I try to use it. Machine will start if I move dial into correct position and hold it there and turn it a bit. Thank you.
  • 185 Answers
Put a new timer in it
Posted on Mar 26, 2008
Does not enter drain and spin cycle on delicate setting
Machine stop at 51 sec after started ,start button flashing nothing is happening ?
Dec 29, 2013 | Amana Washing Machines
Machine stops in the middle of the cycle. I had only a robe and pair of pajamas in the tub and water level set at medium. I moved it to "spin cycle" to get the water out of clothes, but nothing...
Same problem as yours. The GE repair man is at our house right now for this problem. It's the motor, and the "special motor and clutch package" has to be specially ordered.
Jan 04, 2011 | GE Profile WPRE8100G
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Performa washing machine not spinning
you will most probably find that the inside of the belt that runs on the pulley has been breaking away bit by bit and if the pulley stops where there is a bit missing it may not turn when the pulley starts to turn.
Just a thought as it has happened to me a few times
The odor is most probably burning rubber as the pulley spins on the belt
May 26, 2009 | Maytag Performa PAV2200
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Feb 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Washing machine not cycling
"...can hear the electrical contacts trying to hit". The timer may be defective.
Oct 05, 2017 | GE Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
116 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
