Question about Canon PIXMA iP4000 InkJet Photo Printer
White lines pictures have tiny, faint white vertical lines every quarter inch
  • TONESTER May 11, 2010
    I need more info, do the lines cover whole screen, and does it have a washed out, or brighter than normal picture that looks dull, and is the left side of screen darker than the rest of screen? I have seen the RGB capacitor cause this problem, but you will need the schematic, or know the main module to find the right capacitor to check for being good....generally it is a 10 micro farad at 250 volts...if it is good, the problem is going to be possiblely a vertical circuit problem..cap related...especially if the little white lines affect only the top half of picture, called vertical retrace lines...the other problem has to do with the high voltage and screen voltages. Good Luck...T.
Not sure but I think this question was regarding a printer?
Posted on Mar 12, 2008
Vertical lines through Polaroid z2300 printed pictures
i have the same issue, my best guess is that because there equally spaced there is something wrong with a cog, i can hear a faint click that is in sync with the lines. i'm going to investagate more so will hopefully i'll have a definative answer soon
Apr 15, 2013 | Polaroid Z2300 Instant Print 10mp Digital...
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
JVC AV-K21TR
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jan 26, 2008 | JVC AV-27230 27" TV
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Horizontal bands
you may have a problem with the vertical output IC.
May 26, 2007 | RCA F27442 27" TV
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Canon PIXMA iP4000 InkJet Photo Printer Logo
213 people viewed this question
old marine
old marine
