Question about Kenwood KTS-300MR CD Receiver
Volume buttons everything else on the receiver works fine, but the volume buttons don't. it is an all weather receiver but there was some very light rust around the edge. do i need a new face or is it something in the receiver. i took it to my local place who tried some sodering and cleaning but couldn't get it anywhere.
  • 1,512 Answers
The tact switches have failed to the vol up and down switches. This is common as they do the most work. replacing the switches will fix it
Posted on Jan 12, 2008
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
Tv volume stuck on max, volume + signal stuck, button is fine.
The problem is on the board with the controls----if remote receiver is not on same board disconnect that board--if it is unsolder the vol and channel buttons--the front buttons have priority over the remote--buttons will look fine but the switch under each will be your problem---better hope it is as only other cause is a microprocessor gone mad.
If you have a Ohm meter I can tell you how to prove this--going to have to get at the buttons--if you want to prove it is or is not a issue with the micro switches you are going to have to unsolder or test them.
SD TECH
Apr 26, 2012 | Televison & Video
Some buttons on my remote for my yamaha htr 5750 amp don't work. It's the original and was given to me. The volume and power buttons don't work or make the red lite flash; however the other...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 10, 2011 | Yamaha HTR-5750 Receiver
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
My iphone will not ring when called. I have checked settings and all look good. I can hear my alerts, alarms and when testing ringtones (and volume is up). However, when I receive an incoming call, i...
try checking the mute button on top of the volume buttons. if you see an orange dot or line, it is on mute so slide it to hide the orange dot or line and the phone should be fine.
May 09, 2011 | Apple iPhone Smartphone
CB receive volume is low to out on the output. Weatherband output and reception is fine. Any suggestions?
The problem could be with the mic. If there is a problem with the mic it will make either the receive not work, or the volume seem real low. The weather will work fine if the mic is bad.
Sep 29, 2010 | Radio Shack TRC-447 CB Radio
Need to make sure programmed
Program the Midland 74-109 Weather Radio
a) Turn unit on. Extend the antenna. Adjust volume up slowly; Do you hear anything? If not, try replacing the 9 volt battery with a fresh one, in the accessible battery compartment underneath the unit. Repeat above steps.
b) If no sound is heard, turn unit over and look for "WEATHER" slide switch on bottom. With unit on & volume adjusted to comfortable hearing level, slowly slide switch down (or up) through various frequencies [1)162.550, 2) 162.400, 3) 162.475, 4) 162.425, 5) 162.450, 6) 162.500, 7) 162.525] until voice transmissions are heard. This should be the closest National Weather Service (NWS) broadcast for your area. Check the NWS website at http://www.nws.noaa.gov/nwr/nwrbro.htm for your state, click on the state name, and look for the site name or site location nearest you. The frequency for that site should be the strongest, and appropriate for your area.
c) You can set the alert tone, for special weather alert broadcasts, on the bottom of the unit on the slide switch marked "ALERT". Set the switch to the desired type of alert: 1) LED [LED on top of unit (marked ALERT) lights up when alert is broadcast-no siren tone/alarm is heard] 2) LED & ALARM [LED lights up and alarm/ siren tone is heard] 3) VOICE [LED on top of unit lights up and voice broadcast is heard, only; no siren tone/alarm is heard].
d) Be sure to press the "ALERT" button on top of the unit and leave the volume at a comfortable listening level to hear weather alerts for your area (Alert LED on top of unit lights up to show Alert function is active). You can test the present volume level by pressing the "TEST" button. Be sure to press the "ALERT" button again after listening to the volume level to re-set the Alert function. You can listen to weather broadcasts anytime, by pressing the "WEATHER" button. After listening, be sure to re-press the "ALERT" button to reset the Alert function.
e) 9 volt battery life should last about 6 to 7 months, depending on how much unit is used an number of alerts received. Replace battery every 6 months, or when you replace your smoke alarm battery, or at beginning and end of daylight savings time. A 12 volt AC adapter to replace the battery, can be used. One should have been supplied with unit. If not, a replacement can be found at Radio Shack.
f) This should complete your Midland Weather Alert Radio Model 74-109 programming.
Apr 09, 2009 | Midland 74-109 Weather Radio
Audio problem
Depending on what type of remote you have the DVR volume may need to be turned up. On the DVR remote hold the cable button until the lights blink. Then press volume up. The Light should blink again. Turn your volume up on the DVR to "stereo". Hope that works.
Jan 10, 2008 | Arris DCT6200 DTV Receiver
No buttons work...not even the volume and others along side
I had the EXACT same problem this morning. After leaving the cingular store where the guy just wanted to sell me a new phone, I went home and took the phone apart - just took off the battery cover, battery, sim card and the rest of the back cover, reattached cover, put everything back together and everything works fine now! Try it - good luck! You need a T5 torx bit to remove the two screws holding on the back cover.
Aug 31, 2007 | Motorola Mobility RAZR V3
Kenwood KTS-300MR CD Receiver Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
