Leaking condenser tumble dryer
Water leaks from bottom of Hoover Nextra condenser dryer when in motion as apposed to collecting in the reservoir
  • elvispres609 Jan 24, 2009
    leaking condensor all water coming out of bottom of machine and not going into the water bottle everything looks in place at the back. please help
  • kirkykirk Mar 26, 2009
    I have the same problem on our Hoover Nextra - I think this is caused by a leaking seal at the very rear of the heat exchange chamber. If you pull out the exchanger unit , and look right at the back , at the bottom there is a seal to keep any water in the white plastic area, our seal has lifted, thus leaving an opening for water to escape. I'm working on how to get at this seal , as the only access is from the front of the machine.
I have the same problem i need help sick of putting towels down infront of it
Posted on Oct 02, 2010
I have a Hoover nextra 6 kg condenser tumble dryer which is leaking water and the collector is empty and seems not to locate fully into the hole at the back?
Check for Lint/Dirt in the Drain and then you need to ensure it is fully connected in the Washer to the Drain...
Jan 03, 2015 | Hoover Dryers
Hi, My 8kg Hoover Tumble dryer Vision HD stopped working, first a filter care light, so cleaned the filters and now the light comes on but nothing happens. Any ideas? Thanks Matt
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Jan 08, 2011 | Hoover Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
There is no heat
Disconnect power and access your dryer fuses. Check and test your fuses for "continuity". Most likely, a white thermal fuse. Can possibly be your ignitor or heat element as well. Is your dryer gas or electric?
Jan 27, 2009 | Hoover Dryers
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Not collecting water in the tank
I also have this problem and is leaking all over my floor underneath...i've only had it a day. the condenser is soppin wet and no water in the tank..i'm dead angry...anyone else have an idea how to fix this mother F*****...thanks...clair
Sep 21, 2007 | Zanussi TC7102W Electric Dryer
Washing Machines Logo
1,158 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
