Question about KitchenAid KGST307 Gas Kitchen Range
KGST307HBS9 - Burner ignitor not clicking
I've had this range for about 5 years now, just started having a problem with the left front burner. When I try to light it, I don't hear the ignitor clicking, but gas is coming out. If I leave it in the light position for a few seconds it will eventually click and ignite. This problem is intermittent. Although it wasn't dirty, I cleaned around the ignitor and the problem still occurs. I'm assuming I need a Spark Switch/Harness Assembly, but don't know where this is located. Do you think this is the problem, and if so, how do I cahnge it out?
Thanks.
Rich
There is a switching contactor that works in parallel with all of the switches. so if you want you can give that burner gas and use another burners switch. To fix you need to take of the front panel and ether replace the harnes http://www.partselect.com/PartDetail.aspx?Inventory=731688&SourceCode=1
or fix it usually the spring like copper contacter is just streaches a little further than it should and is not making contact
Posted on Sep 01, 2008
Left front burner not igniting...no spark but has gas,
automatic re ignition control (spark module), that's a common issue on all viking stove.
appliancesrepairla.com
May 12, 2010 | Viking VGIC485-6G Gas Kitchen Range
I have a Kitchenaid superba gas range slide in, model #KGST307HBS9. The nob of one burner, only, the left rear, will initiate the electronic spark that will light burners. When that nob is turned to...
Pull out the bottom drawer and you will find the spark module. I strongly suspect it is weak. Here is a video that shows operation:
This one shows the module on the backside but I looke dup yours and it is below in the backside of the bottom drawer. Ok here is what i think The igniters could be dirty and I have a video showing how to check that plus another video to show how to remove those pesky switches on the top burners and spark module operation.
TOP BURNER SPARK IGNITION
SEALED BURNER SCREWUP
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2010 | Kitchen Ranges
Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Jun 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
One burner does not ignite when the others ignite
hi there,
the clicking sound is good, that means that the spark module is working and you have power to the stove. you may have a faulty gas valve or ignitor. most gas ranges have electrodes as ignitors. check the ingitor before you look at anything else.
Oct 03, 2008 | Kitchen Ranges
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Aug 26, 2008 | Jenn-Air JGS8850BDS Stainless steel Gas...
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
Sep 25, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
KitchenAid KGST307 Gas Kitchen Range Logo
384 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
