Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Blue screen Our tv was on today when out of nowhere the screen turned blue. we turned it off to let it cool hoping that might help but it didn't. when we turned it back on a faded picture emerged only to go completely blue again. Husband looked inside the tv to notice that when turned on again, the blue projector was fine, while the red and green quickly faded as seen before.
  • 4,402 Answers
Convergence ic and resistors require replacement and that you need to check for cracked solder.
Posted on Jan 15, 2008
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Numbers and letters look blurry
rear projection tvs have coolant to cool pix tubes which goes bad in the blue and green verrify-remove front of tv-outer edge unclips-take out screws arround screen-carefully remove screen-now turn tv on look down into blue/green tubes--pix is bad--blue is so bad you cant even see the can call a local shop-get quote to replace fluid--if its too much and you are mechanically inclined email us-we will let you how to do it for free-hope i helped you
Sep 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Our 1991 RCA projection TV P52150CP started being hazy blue when first turned on then it gradually would become mostly normal screen. Today the whole screen is a blue haze. You can see the picture sort of...
Most likely it is the Blue CRT Driver Board or the Blue CRT failing. There is no quick way to varify unless you call a repairman out to see.
Hope this Helps,
Jul 03, 2009 | RCA P52926 52" Rear Projection Television
Hdtv with yellow half circle on bottom of screen
Odds are real good that the cooling fluid in the blue picture tube assembly has become contaminated. Only solution is to pull blue crt and dump out old fluid and clean and reinstall new fluid. Once done a fair amount of re-alignment is required. This is not a job for a do-it-yourselfer. Most tv shops would charge in the area of $250 to $300 for this repair.
May 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Blank Blue Screen
If you go to menu do you get that on the screen?
Nov 21, 2017 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Nov 13, 2008 | Televison & Video
Blue screen on tv
I too have the same problem with the blue screen and also some dots in the center of the screen. I went to the sony site ( and found the answer. They will repair the unit until Dec 31, 2008. hope this helps
Nov 09, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
109 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
