Question about Epson RX620 All-In-One InkJet Photo Printer
Cant use my copy button
Moved the printer and now it wont set up 2 copy
  • Epson Master
  • 1,879 Answers
>make sure printer is not connected to a computer
>powercycle the unit
>try pressing the copy button again
>issue persists : hardware issue / contact the vendor
Posted on Jan 03, 2008
Reset mp390
1. Press ON, ADDITIONAL FUNCTIONS, SCAN, COPY, SCAN
This will enter into Service Mode
2. Select Test Mode, last selection, use + button then press SET
3. Select #8 Printer Test, use + button then press SET
Printer will start and stop
4. LCD will shown 8-2, press + to move to 8-3, press SET
5. LCD will shown EEPROM CLEAR
Select Ink Count option 0 and press SET
6. Press STOP/RESET
7. Press ON
Dec 31, 2013 | Office Equipment & Supplies
I cannot fix the problem Error code 2 & 7
Manual Reset for Canon Pixma MPC190 Printers
1. Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
2. Choose TEST MODE.
3. Select 8 PRINTER TEST -TEST MODE.
4. Choose 3, EEPROM CLEAR
5. Select 0, INK COUNT
6. Press the Set button.
7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 11, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Printer wont power up, 3 lights flashing on main panel when plugged in, including power button. photo,copy & the scan lights. How can i recover from this?
1. Check your wire for a possible short.
2. Reinstall your printers software.
3. Update your printers software.
4. Update your drivers
Check into the 4 of them first
Jul 26, 2010 | Dell 922 All-In-One InkJet Printer
Its telling me no scan option
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab1
Jul 16, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart C4580 wont scan
It seems that scanner glass is not glowing or may be bulb are not moving properly.
you can try these thigs:
1)Turn ON the printer unplug the powe cable from the back of the unit; wait for 30secs; replug the power cable.
2) Try this to check teh funtionality of hardware Load letter or A4, unused plain white paper into the input tray.
  1. Press and hold the Cancel (c01235250.gif ) and the Start Copy Color buttons at the same time.
  2. Release both buttons. The self-test page prints.
3) Now check if its copying or not?
It will work fine(if your printer scanner glass is fine)
You can also try scanning from computer(if installed)
the location of file would be=
c:\program files\hp\digital imaging\bin
here locate for file "hpqscnvw" hit it and try to scan
Best of luck
Jul 04, 2009 | HP Photosmart C4580 All-in-One InkJet...
Clean unable 46
You need a new ink absorber box which can be purchased from a brother service partner near your home.
www.brother.com
If you have got the spare part (ink absorber box) you have to open the printer:
Do NOT clean the old one! It cant be cleaned: The felt wont take up ink anymore and will stain the machine from inside and the furniture beneath the printer.
After replacing the eeprom of the printer needs reset:
(dcp: use arrow-up and set key to choose the digits. e.g. arrow-up til 8 then set arrow up til 0 then set
mfc: use the fax-number keys.
Stop-button will always go back to maintenance, if you have done wrong)
press menu then start bk-copy then fourtimes arrow up quickly after another.
machine will switch to maintenance mode and light(s) will flash.
press 8 0
press start bk-copy until PURGE 64xx
press 2 7 8 3
Purgecount will be 0000
Press stop
press 9 9 to leave the maintenance mode.
After the mfc/dcp comes up again in normal state the error has disappeared
May 14, 2009 | Brother DCP 130C All-In-One InkJet Printer
Files wont copy or be moved into folders
Are the files/ folders you are trying to copy currently in use?
Do have the rights to move files?
Mar 25, 2009 | Apple Computers & Internet
Lexmark X5100 printer. I copied a small item 3x3 and doubled its size. Now when I try to copy a full page only one small corner is reproduced. It appears I lost a default setting. How do I get a full page...
If you are using your All-In-One without it being attached to a computer and scanning a document that is getting cut off on the edges:
1 Move the document to a different place on the glass.
2 On the operator panel, press the Reduce/Enlarge button
repeatedly until Fit to Page appears.
3 Press Select.
If you are using your All-In-One attached to a computer:
2 From the software, select a copy setting with autocrop on (Color Photo or Black and White Photo) to make sure that autocrop finds the object and prints it completely.
1 From your desktop, double-click the Lexmark X5100 Series
All-In-One Center
icon. The All-In-One Main Page appears.
2 Click Preview Now to see your scanned image.
3 Select a quantity and color for your copies.
Note: To choose a paper size or further customize your copy
job, click See More Copy Settings.
4 Click Copy Now.
Note: When autocrop is on, the object (wherever it is placed
on the glass) will be printed in the upper left corner of the
page. This might make your copy look different from the
original.
try the above and post back so I know if your issue is fixed or you need more assistance
Jul 12, 2008 | Office Equipment & Supplies
Canon pixma 530
unplug it from power and plug it back in.
if that doesnt work try unplugging it and GENTLY try moving the ink carrage to make sure it isnt in some odd position that the porinter cannot detect.
IF the carrage is properly seated on the one side of the printer it is normal for it to be locked and seated on pads that keep the ink from drying out.
May 02, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Epson RX620 All-In-One InkJet Photo Printer Logo
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
