Question about Panasonic NN-S550WF Microwave Oven
NN-750WF panasonic Tengo dos micro onda NN-750WF Las targetas se pueden reparar pero no tengo diagrama para ver los valores de los componente que se quemaron puedo comprar dos modulos si puedo conseguir los diagrama los puedo reparar Gracias David Tabar
3 Suggested Answers
  • 2336 Answers
SOURCE: no est? funcionando
El codigo H98 indica que puede haber un magnetron defectuoso, tambien que puede haber una fuente de alimentacion defectuosa o puede ser que exista un falso contacto en el connector CN702. Han habido reportes que la fuente de voltaje ha salido con poca vida y fallan a menudo.
Si habres este aparato ten cuidado con el alto voltaje que existe en un condensador de alto voltage.
Suerte.
Posted on Jan 24, 2008
SOURCE: control remoto danado
switch o the microwave and off for three consecutive times.
Posted on Sep 25, 2009
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Service manual of macrowave Avanti M09003SST
You can't get service manuals as there are no user serviceable parts. Only dealers can get them. The screws holding the case as security screws which only dealers have the tools to open. Microwaves can kill and blind you in 15 seconds.
No puede conseguir manuales de servicio ya que no hay elementos manipulables. S?lo los distribuidores pueden conseguir. Los tornillos que sujetan el caso como tornillos de seguridad que s?lo los distribuidores tienen las herramientas para abrir. Microondas pueden matar y cegarte en 15 segundos.
Dec 12, 2015 | Avanti M09003SST Microwave Oven
COMO REPARO UN MICROONDA PANASONIC CON ERROR H98
H97, H98 o H99 significa que hay un problema con el inversor, magnetr?n, o el circuito de programaci?n digital.
Debido a las tensiones letales utilizados y producidos, no se recomienda que una persona sin experiencia de trabajo en estos. Yo recomendar?a que se ponga en contacto m?s cercano de servicio autorizado de Panasonic.
Soluci?n de problemas de circuito inversor (U) y Magnetron
Este horno est? programado con un sistema de auto diagn?stico c?digo de error que le ayudar? a solucionar problemas, H97, H98 y H99 son el fracaso y el inversor siempre magnetr?n ?reas problema en el circuito. Esta secci?n explica los c?digos de falla de H97, H98 y H99. H97, H98 y H99 aparece en la ventana de visualizaci?n poco tiempo despu?s de clave de arranque es presionado y no hay oscilaci?n microondas.
Forma alternativa para solucionar el horno con aire acondicionado Ampere medidor utilizado.
H97, H98 y H99 aparece en la ventana de visualizaci?n un corto tiempo cambiar clave de inicio es presionada y no oscilaci?n de microondas con amper?metro de CA utiliza para solucionar problemas.
Compruebe filamento del magnetr?n abiertos o en cortocircuito a la carcasa antes de proceder a determinar un buen magnetr?n.
Espero que esta informacion le sea de ayuda (recuerde valorar esta respuestas gratuita).
Sep 20, 2011 | Microwave Ovens
Microwave ne se rechauffe pas
Premierement, assurez vous que le niveau de pouvoir est sur le maximum (10).
Si ca n'est pas le probleme, vous probablement aurez besoin d'un micro-onde nouveau.
Il y a un parti a l'interieur appeler le Magnetron qui ne fonctionne plus. Avec le cout de travaille, remplacement de cette parti peu couter jusqu'autant q'un nouveau machine complet.
Si votre machine est presque nouveau, contactez le magasin ou vous l'avez acheter, et demandez un retour ou echange.
Outrement vous devez acheter un nouveau. Essayez de faire un peu de recherche sur l'internet avant d'acheter un autre. Le modele que vous avez a recu beaucoup de plaintes de mauvais qualite.
http://www.reviewcentre.com/reviews126097.html
Desole de vous donner les mauvais nouvelles.
Merci et bonne chance.
May 12, 2011 | Neff H5430 Convection Microwave Oven
Display panel has lost most of its dots. can't read it
debe ser revisada por un tecnico por que parese ser la targeta de control da?ado por incectos o por cucarachas
Oct 05, 2010 | Sharp R-1750 Microwave Oven
NECESITO PORFAVOR EL MANUAL DE USO DEL MODELO, NN-ST657W
Si sabía el problema que podría asistirle mejor así que debo conjeturar: Ninguìn calor: maìn magnetrón, fusible soplado, maìn diodo del condensador, abierto o puesto en cortocircuito. Si sopla el triturador es probablemente un maìn magnetrón. si simplemente ninguìn calor es probaby el diodo y el condensador.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 17, 2009 | Panasonic NN-S954WF Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
No est? funcionando
Suerte.
Jan 24, 2008 | Panasonic NN-S768BA/WA Microwave Oven
Panasonic NN-S550WF Microwave Oven Logo
108 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
