Question about Symphonic ST419E TV
My symphonic st432f won't turn on!
My television isn't even a yr old. one day it worked fine then the next day i went to turn it on and it won't turn on. it hasn't turned on since. what can i do? the model is a st432f.
2 Suggested Answers
  • 1694 Answers
SOURCE: reset button
No reset button for a long time on any brand of tv.....
Check horiz output transistor,fuses and power supply
Posted on Dec 21, 2007
SOURCE: symphonic television no sound
The no sound solution I have found, to come from, believe it or not, a dirty or broken earphone jack...the capacitor is bad and it has a direct link with the sound and speakers...easy fix if you just clean the points...a cap on the other hand might be hard to come by.
Posted on Sep 06, 2008
0 characters
1 Points
Symphonic TV has no sound unless I am playing games.
Could be something wrong with the tuner inside of the TV.
Oct 22, 2012 | Symphonic Standard (CRT) Televisions
Need to get a unversal remote one for all to work
These are the setup codes for Symphonic with universal remote control.
0053 0189 0227 0456 0024
Buy one universal remote control, which has one among these setup codes. You can get details about codes, from the code list attached to the remote control. Brand isn't matter.
Apr 27, 2012 | Symphonic ST419E TV
Symphonic 20" television will only get three local channels
I suspect your tv has gone back to air and should be in cable mode; you will have to go into menu where channel programming takes place. Select cable and autoprogram; it should pick up the missing channels.
Jul 16, 2008 | Symphonic ST420FF 20" TV
No Picture or Sound
I dont think it's worth getting a repair man to come fix a Symphonic TV... honestly, they are problem prone... and It would cost much less to just buy a whole new one. I have a symphonic tv with no remote, and now, I cant switch into game mode! It's like they designed their tv's to be crappy!
Jun 07, 2008 | Symphonic ST419E TV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Reset button
Dec 21, 2007 | Symphonic ST419E TV
Television question
****. Same problem. No luck on the down from channel 2 thing. Fuckin old crappy tvs.
Jun 21, 2007 | Symphonic ST413C 13" TV
Symphonic ST419E TV Logo
252 people viewed this question
Top Symphonic Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Symphonic Standard (CRT) Television Expert? Answer questions, earn points and help others
