Question about JVC GR-D270US Mini DV Digital Camcorder
Memory card I?m using the recommended memory card for my camera(GB SD). I am experimenting taking still photos however; when the card is inserted into my reader (HP6310 all in one); I can not retrieve the photos. The photos taken on a previous card with a different camera come-up. What am I doing wrong?
  • Anonymous Mar 27, 2014
    Never had any problem before, when I put sd card in camera the camera says no memory card
  • 205 Answers
When you use an SD card in mulitple cameras, each camera creates it's own folder beneath the DCIM folder. I'm not sure if you have a program that automatically opens when you insert the SD card in your reader, but perhaps you can try double clicking on "My Computer" and locating your reader/SD card and opening that folder manually. Once you're there, open the DCIM folder and see if there are multiple folders inside. Open each one to see if you can locate your pictures.
If you have a program that opens automatically when you insert the SD card you'll need to figure out how to tell it to look in other folders.
Posted on Dec 28, 2007
  • ohiotom Dec 28, 2007
    One more thought...can you see the pictures on the memory card when it's inserted in the camera?
I recently bought the vivitar 7024 and bought an sd card lexar multi use 4 gb. For some reason when I take photos and try to look at the pics it says no file exist. But when I take the sd card out and I...
Apparently, you have pics on the camera's internal memory. Your card won't work until those pics are gone. Here's how...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work.
Aug 18, 2011 | Vivitar ViviCam 7024 Digital Camera
When I turn on my Vivitar DVR 410,it says:Memory Full! Please insert an SD Memory Card.Then when I insert my card, it still says Memory Full! Please insert an SD Memory Card.It wont let me take a...
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
May 28, 2011 | Cameras
What to do when it says internal memory full
Delete some pictures off you camera. It means that there is no more room on your memory.
Make sure to transfer them to a computer, before you delete them, as you wouldn't want to lose precious memories.
If you found this answer helpful, please rate it.
Mar 14, 2011 | Kodak EASYSHARE Z1485 IS Digital Camera
After taking only two -three photo , camera is displaying memory full, please help me with this
Hello - You're camera has a little less than 10 MB of memory with sounds exactly right (2-3 photos) with a 12 megapixel camera. Such images are large.
You need to purchase a memory card to insert into your camera to store pictures. Your camera takes several kinds of memory cards but I suggest your purchase a SD memory card of two GB in size. You can get them almost anywhere, Super Markets, Chain Drug Stores, Places like Walmart, Kmart, etc. It'll cost about $15 or so.
Happy Photo Snapping, Mikeywaf
Mar 09, 2011 | Samsung SL605 Digital Camera
When pictures are taken they are being stored on the camera. They do not go to the SD card.
You need to get rid of the pictures in the internal memory. If you want to save any of them, go into the menu and find "copy". You will find the option to copy them to a memory card. Then, with no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. Then your card should work properly.
Dec 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
I just bought a sanyo camera vpc-t1495 and took 2 pictures and now its saying memory is ful. what do i do to correct this.
Good day,
The camera has a small internal memory that you can use to store photos on. The internal memory is normally not enough to take a lot of photos. You are able to delete the current photos by erasing the memory or deleting the photos one by one.
The solution is to purchase a memory card. I would recommend a 4 Gb SD Card.
With the extra space the memory card provides it will take a while before you run out of memory. When the card is starting to get full download all the images to your computer and erase the SD Card.
Hope this answers your question!
Regards
Nov 29, 2010 | Kodak EasyShare V1003 Digital Camera
Cant gat my vivitar 5024 to take its card
Your Camera supports a SD Memory Card up to 8 GB. But, its always recommended to use a 1 GB or 2 GB card since higher the capacity, faster will your batteries get drained. And since the 5024 takes in AAA batteries, they will be drained out really quick.
Locate the Memory Card slot. You should find it on the side of the camera just above the Macro/Normal Switch. Now, insert the memory card into the Camera. The Golden lines should be facing downwards and the angled cut part should be the first to enter. Gently push the memory card in and wait for the "Click" sound. An SD symbol should appear on your LCD screen. This shows the Card has been recognized.
Remember to use a memory card with a small capacity as it lets the battery last longer.
Aug 27, 2010 | Vivitar ViviCam 8025 Digital Camera
Can't access photos on 2 GB SD camera card.
You may try some photo recovery software to rescue the files on your digital camera sd card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Mar 22, 2009 | Canon PowerShot A540 Digital Camera
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
JVC GR-D270US Mini DV Digital Camcorder Logo
143 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
