Question about Toshiba 50HX70 50" Rear Projection Television
Service Mode I am just about ready to change my ic's for convergence problems. I heard that once I have changed them that I will need to enter service mode and adjust things from there. I have this television second hand so I have no idea how to enter service mode on it. Any ideas would be appreciated. Thanks.
  • JustinMan Dec 28, 2007
    I was hoping to find a way to enter service mode without purchasing the manual.
    Thanks
    Novelist:
    Champion:
  • 232 Answers
JustinMan, if you use original IC`s (not the el-cheapo chinese copies) the odds are good you will need no or minor adjustments which don`t require the need to go into service mode which you really shouldn`t go into unless your experienced with tv repair, you should be able to order the serv. manual here, www.partstore.com it will give you the parts list and set-up procedure, good luck, BMW Rider
Posted on Dec 28, 2007
  • Larry Eastman
    Larry Eastman Dec 29, 2007
    Justin, I`ve been a tv tech for 29 years and I would NEVER go into the service menu and start changing things without the service manual, you can REALLY screw up your set doing that, which will of course cost YOU more money when a tech comes out to get it right again, do yourself a big favor and either purchase the sm or just call a tech, trust me it will save you lots of grief and aggravation, BMW Rider
Akai/Samsung PT4299HD Convergence Problem
Try resoldering the pins on the ICs first. If that fails to resolve the problem, change the IC responsible for RED. You should be able to determine that from the service manual. In that area you should also see either fuses or low valued resistors that feed the STKs. Check those as well.
Let me know if you need further info.
Dan
Feb 13, 2009 | Hitachi 53UWX10B 53" Rear Projection...
50H13 Red Convergence Problem
I do wish people like troylove11 would stop giving advice on things they obviously know very little about. The Toshiba projection sets never have loose connections on the convergence IC's, and there are never bad resistors in those sets. There is no separate convergence board and there are no adjustments on any boards. The convergence adjustments are done electronically, through the remote in the service mode. Also, moving or bumping a projection set cannot cause a solder joint to crack loose. Your set has 2 large convergence IC's and one of them has burned out. This is very common in projection sets. Do not attempt to enter the service mode to make adjustments, because you will only be messing up the correct settings and when the new IC is installed, the colors will still be way out of alignment. Replacing a convergence IC is a very simple thing for an experienced tech, and it is well worth getting the set fixed. If your set uses the STK392-010 IC's, it is probably a good idea to go ahead and replace both IC's with the newer, upgraded STK392-150 IC's. If you have not changed the convergence settings, the picture will return to normal once the IC is replaced and very little realignment will be necessary. When I do a housecall for a set like that it takes about an hour and a half and I charge $150, but shops in your area will vary so ask around.
Sep 07, 2007 | Toshiba 50H13 50" Rear Projection...
Convergence is off, can't seem to fix.
If u change any of the convergence IC's, u need to re-align the set.
For this U need the service manual
Rifaa
Oct 01, 2008 | Sony KP-51WS510 51" Rear Projection...
43F300 convergence
convergence kit # x480306 , dont go into the service mode unless you know what your doing in there and what your adjusting./st.
Aug 22, 2008 | Hitachi 43F300 43" Rear Projection...
Panasonic PT-47wx49E
you have to go into service menu to reset convergence after changing ics.I never posted this because if you do not know how you can shut set down.which chassis do you have ? There is 3 diffenert ways to enter into service mode for convergence.
Apr 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem
Well you need to get into your tv's service menu and service convergence mode. It's different for every tv. It means entering a code on the remote that opens up a secret menu for changing tv settings. Go to servicemanual.net and buy the service manual for your set, you'll be glad you did.
Mar 23, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Service mode for convergence
You enter the service menu by using the remote. Press DISPLAY, 5, VOL+, POWER in rapid succession. Once the screen appears, you should notice green letters and numbers at the top of the screen. Your remote acts as a navigation tool to allow you to select and change values. Keys 1 and 4 change the Item, keys 2 and 5 change the Category, and keys 3 and 6 change the Value. MUTE enters the write function, and ENTER executes it. Power exits the service menu. Keep in mind that while in the convergence mode, the keys have different functions, which we'll get to in due time. The service manual will also have this information.
http://tv.groups.yahoo.com/group/Ws500/
Feb 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Factory settings
I have heard of a reset in the factory 2 position of the service menu. Click the button behind the little hole in the front panel a second time and it goes into 2nd service mode.
I have never used that mode, I only use the first sm, but have heard that you can reset your conv points that way. You'll still have a lot of work to do afterwards, of course.
Once the STK ICs have been changed out/replaced when defective, the conv should still be roughly where it was before and only need trimming. Only once has a massive shift happened when I have done this, which needed massive corrections. So it does happen, but only very rarely.
I offer phone consultation, if you wish, to get it really good in there.
www.imageperfection.com
Mr Bob
Dec 28, 2007 | Pioneer PRO-710HD 64" Rear Projection...
Toshiba tv convergence problem
did you change the resisters the same time as the ic? some have reported that they got generic IC (cheaper) and have failed.
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 06, 2007 | Toshiba TP71G90 71" Rear Projection...
Toshiba 42H82 convergence problem
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Sep 19, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 50HX70 50" Rear Projection Television Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
