Home | Zenith | B25A02Z TV | Color Adjustments....
Zenith B25A02Z TV
Problem for Zenith B25A02Z TV
By bosoxfan on Dec 28, 2007
I'm working on the color adjustments for my parents television..(Zenith) Most of the time, the color and objects have a green hue to them.....I am looking for the standard settings for the television, so I can set them manually. Can you give me the suggested setting rates for each of the settings...(i.e. color, sharpness, contrast, etc.)
The adustments are made on a line system, with a vertical bar that goes up and down the horizontal line, instead of being able to run the adjustments up and down by either an amount ( some tv's might say, color 50 contrast 30, etc) With the line system the way it is, you pretty much have to guesstimate......can you give me an idea where each of these should be set?
Can you please help?
Thanks!!!
Same Problem
Apr 29, 2009
-   is the same but is blue -   Guest
Best Solution
posted on Mar 14, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have trouble adusting the color on my Mitsubishi TV. I can't seem to find this setting on my TV and I do not have the original remote for it. It's an older TV. I bought a universal remote and still can't find the settings . Can you please help me.
Solution #2
posted on Dec 28, 2007
Not Rated)
onebadss
Rank: Master
Rating: 90%, 20 votes
well it all depends on where the tv is located to, if it is in a room with little or no light( windows, lamps) you will want you brightness to be a lil lighter hince not makin the picture as dark, and vise versa for light rooms, u'll wanna turn the brightness down a lil bit to accomidate this room, as for the others i'd say a lil over 50% on them, thats how my office tv is set up, hope this helps, jason
Was this helpful?
Yes
No
Popular Solutions for Zenith B25A02Z TV
Questions and Unsolved Problems for Zenith B25A02Z TV
Do you recommend Zenith B25A02Z TV?
Answer
Answer
double color red an green 3d light
Answer
I have purchased a new logic 19" flat screen TV. The in built DVD player will not run dvd's. It... (More)
Answer
I have a Zenith 32" TV console and power will not come on by Remote or manual switch. It was... (More)
Answer
I can't seem to find the 3-digit code for the zenith TV B25A02z
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zenith B25A02Z TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
