Question about Bosch SHU5307UC Built-in Dishwasher
How to disassemble the drain component
I have a "slow drain" problem. Only a trickle of water was coming out of the drain pipe at the connection to the sink drain, and since the drain cycle is on a timer, the pump shut off before all of the water was out. I eliminated the air gap and its attached hoses as a cause, looks like a blockage somewhere in the machine's drain line. I was able to pull a little material out of the hole at the bottom of the machine, and that improved the flow considerably, but I need to disassemble that plastic component at the bottom of the machine so that I can clean everything properly all the way through the drain line. I'm requesting a diagram, instructions, or where I can get a service manual so I don't get into trouble trying to take that thing apart. Thanks for any tips.
  • 2 more comments
  • whandley Dec 28, 2007
    Thanks, but when I click on the link I get an error message, "No correct login."
    Thanks, but your suggestion sounds like what I've already tried and as I said, that helped, but there is more in there that I was unable to get out. So it's either try taking that thing apart, or throw away the machine.
    Right, I've already done those things, I'm now at the point that I need to disassemble the component inside the dishwasher, at the bottom, where the drain hose connects. I understand that this could be a bit complicated, that there may be one or more valves inside this component to keep water from backing up, etc. I've already been able, as I said, to pull some material out of that hole and improve things, but I need to take it apart and clean it out properly. I don't want to disassemble it without knowing what it consists of and how to get it all back together, thus I'm asking for diagrams, instructions, etc for disassembling this component.
  • whandley Jan 05, 2008
    No, I'm afraid to use a drain cleaner, I've seen advice on these kind of sites that this should never be done because it could damage seals, etc. Without knowing what is contained within that component at the bottom of the washer, I don't want to risk it. The solution I'm asking for is really quite simple: where can I find a diagram showing me how to disassemble the component inside the bottom of the washer, where the water exits the machine?
    Sergeant:
    Champion:
  • 209 Answers
Yeah, that link does not work, I will try to find the right one.
Posted on Dec 28, 2007
  • Simon Zwaan
    Simon Zwaan Dec 28, 2007
    It might not drain because the drain solenoid[valve] is burned out or your drain line is simply clogged.
    Take the hose off where the drain connects to the disposal and check for clogs.
    You should be able to remove the front panel and locate the drain pipe, if its at the back you might be forced to take away the baseboards/toekick if you have them and slide the whole dishwasher out, exposing the drain pipe.
    http://www.repairclinic.com/0047_9.asp
    That website might help.
    Hope that helped a bit.
  • Simon Zwaan
    Simon Zwaan Dec 29, 2007
    Have you tried using a drain cleaner ?
    like liquid plumber ?
    Sergeant:
    Champion:
  • 298 Answers
Diagram can be downloaded here there are no parts
available click on printer icon with multiple pages
in the lower right corner
  • Eugene Merritt Dec 28, 2007
    They no longer stock parts for that
    model so I wouldn't suggest
    damaging it try flushing with
    straight piece of wire and
    try flushing with water
    pressure if you cant reach
    it from underneath
    after removing the front
    trim panel
  • Eugene Merritt Dec 29, 2007
    Having a diagram is not the problem the piece is threaded
    in you will probably chew it up trying to remove it '
    the part is not available to John Q Public only a
    service part don't tell me you don't know how that
    works If you go to the service counter of a Bosch
    certified dealer they may show you the blowup
    of the part on microfiche or on the computer
    screen they may offer to sell you a service manual
    they may offer to sell you the part if you so desire
    .If you remove the part and go to service/parts
    facility they might sell you the part if they stock it
    or they may be able to order it for you
My Whirlpool gold dishwasher will not drain completly, and if it does, it's very slow
If there are no obstructions in the discharge hose then I belive that the pump is most likely the blame. Something may be caught up in the impellers of the pump not allowing it to create suction. You can also look to see if the electrical connection on the pump has in some way become disconnected via a plug or loose wire.
Jan 04, 2015 | Whirlpool Gold GU2475XTV Builtin...
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains.
you have pets?
have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck
call a PROFESSIONAL
Dec 29, 2014 | Estate Refrigerators
My Kenmore Elite Oasis Ht Top Load washer has a slow drip from the drain pipe. How to stop?
If not during a wash it is standing water.
Remove tube and check for cracks. If so, replace. Does/did the washer "walk"? May have rubbed the discharge tube and caused the leak.
Is the down pipe in a cold external wall? May be condensation from humid air hitting cold.
If the sound is the problem, attach a string to the drain pipe so water drips directly to side of vertical pipe.
Oct 23, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 | Plumbing
Cold water slow to fill
It buzzes because 120 volt AC is within the hearing range and means electricity is trying to open the solenoid plunger.Make sure the faucet the hose is connected to is turned on. swap hot and cold hoses and see if the Hot water is now a trickle. The solenoid asm that the hoses connect to can be removed and dissambled. It's a no brainer. the parts are mirrors of each otherBe sure to unplug the washer first. Remove the hoses at the solenoid assembely the valve asm has wires coming to it that just push on. A loose connector MIGHT cause this problem. Draw a picture of the wire connections, noting the color of each connection.Now the fill solenoid asm can be removed. It's probably held to the cabinet with one screw. now there are some screws holding the coils to the plungers. disassemble the valve and clean it up. Don't lose the springs that push the plunger to the closed position. At this point you could even swap the plungers on the asm. Just clean the obvious lime and **** upp using a tooth brush and water.DON'T LOSE THE SPRINGS,DON'T EVEN WASH THEM. Assembly is just reversed.you should not have to buy any parts, but don't lose the springs.
Nov 30, 2011 | Admiral AW22 Top Load Washer
Only a trickle of hot water is coming out of my faucet. I tried to flush the tank, but only a trickle continues to come out of the hose....am I not doing something right?
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
The link above gives a list of reasons for the decreased water pressure at your faucet.
As for draining the tank, it sounds like it's clogged with sediment.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
To open a clogged water heater:
Connect a washing-machine-hose to water heater drain valve.
Connect garden-hose to outdoor spigot, and to washing-machine-hose.
Turn on outdoor spigot for 10 seconds and it will open the clogged valve.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Nov 07, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Maytag eq plus dishwasher- how to disassemble bottom spray arm?
its probably leaving water in it and is clogged in the elecric pum or drain hose. somethins the pump has a rubber flap that will become lodged in the outlet port. this will cause dirty water to be left in the machine because of a slow drain. start by looking at the volume of water coming into garbage disposal where drain hose hooks up.
Aug 01, 2010 | Maytag Dishwashers
Dishwasher holds water
if you dishwasher holds water that means the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
also it may be due to faulty pump
Servicing the Water Pump
In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Sep 06, 2008 | Dishwashers
Bosch SHU5307UC Built-in Dishwasher Logo
140 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
