Zenith TV I am trying to connect a magnavox dvd player and the tv is not allowing me go down to channel 3 so that I can set it up. What do I need to do?
  • Anonymous Jan 14, 2009
    Ive programed my universal remote and have the dvd hooked up to the TV but I still can not get it to play nor can I get any helpful setups on the menu ,I manged to get it to show av1 and av2 but still no access to dvd player ,, just keeps jumping back to that screensaver
    worse it wont even play the spongebob dvd player that comes with it
    my DVD is a JVC and works on any other TV ..there are no resets nor any other options to fix this ?? frankly this is down right idiotic if you ask me
    Problem Solver:
  • 14 Answers
Have u tried using a universal remote and programming it for your tv? sometimes universal remotes can break a code that a common tv remote cant, hope this helps, just a suggestion!!!!
Posted on Dec 28, 2007
  • 232 Answers
Martha, dvd players don`t have an "rf" connection, so you don`t watch the dvd`s on channel 3 like on a vcr you have to use the 3 cables coming out of the back of the dvd player to "video in 1" on the back of the tv.Yellow to yellow red to red and white to white, (the plugs and connections on the tv & dvd are color coded)
Then switch your tv to "video input" NOT channel 3, to watch the dvd, good luck, BMW Rider
Zenith C27A24T 27" TV does
Greetings - You need to have you DVD player hooked up to the video inputs - See below. Don't mind the mouse scratch out lines. The Device on the right represents your DVD player.
You then have to choose video as your source on the TV (not channel 3 or 4) using your remote - see below.
You should be good to go.
Enjoy your movies,
May 22, 2011 | Zenith C27A24T 27" TV
What chanel do i set tv to to play vcr
Hello, Typically they use either 2 or 3. Your vcr might have a slide switch that will allow you to select either channel. You can usually find it by just switching channels. If it still looks like your not connecting, make sure cables, either coax or rca, are pushed in securely. You can always troubleshoot by trying other vcr or dvd player and also try on other tv.
Hope this Helps
Jan 30, 2011 | Zenith Televison & Video
I lost the manual to the magnavox dvd/vcr dual player so i dont know how to set it up. so i can watch dvds and vcr tapes.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from, you will need a model number.
Mar 19, 2010 | Philips Magnavox DVD/VCR Dual Player
How do I connect my magnavox dvd player to my tv?audio in or video out? I also have wave braodband but disconnected
Audio out and video out should be connected to the tv using rca jacks. Or you can use the cable connection to the tv and set the tuner to channel 3 or 4.
Sep 26, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to connect a 1999 zenith TV to a cable box and
Connet the output of the cable box to the DVD player and the TV out output of the DVD player to the TV (TV must be tuned to Channel 0, Chanel 3 or 4). You should be able to use the remote to switch between the DVD signal and the cable signal.
Hope it helps.
Sep 08, 2009 | Zenith A25A23W 25" TV
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
Mar 06, 2017 | Zenith SY2569X TV
Magnavox DVD.VCR player.
The remote code for magnavox dvd/vcr dual player is, 21593. It work for me..
Jan 21, 2008 | Philips Magnavox DVD/VCR Dual Player
Hooking up a magnavox MWD7006 DVD player to a APEX TV
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
Jan 13, 2008 | Philips Magnavox MWD7006 DVD Player
Trying to watch vcr on channel 4, but the vcr is set to channel 3
You can watch the TV programs
with the tuner of the unit. (Usually
channel 3 or 4 of the TV is
available for the RF converter
setting.) Be sure to connect the
unit to a TV using the RF cable.
Select channel 3 on your TV.
Press [VIDEO/TV] on the remote
• If noise appears, change the
RF output channel of the unit to
CH 4 by pressing [VIDEO/TV]
for 3 seconds. The RF output
channel will alternate between
CH3 and CH4
Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
Connecting dvd player to zenith sy2551s system and doesn't work
Yes, You need to be on AUX ,you can get to that setting by pressing channel 01 then press the channels down button instead of going to channel zero it will start to cycle through your AUX's inputs on the back of the tv.Also, another way to do this is on the original remote there will be a SOURCE button or INPUT button that can also cycle your TV through the aux inputs.REMEMBER.Make sure your DVD player is turned on and hooked up or else the AUX screen will be black.Rate me when you fix it!GOOD LUCK
Nov 18, 2007 | Zenith SY2551S TV
Televison & Video Logo
318 people viewed this question
Top Televison & Video Experts
