Question about One For All URC-4021 Remote Control
URC4021 Last Button
When the last button is pressed, it always goes to channel 16 not the last viewed channel. Any help on this one?
Hat is the code for the control 4021 for a sharp tv
Posted on Jan 04, 2008
I have direct tv and accidentally changed the channel on the Samsung tv manually now I don't get my direct tv what is the defalt channel fo the samsungg
Press the last channel view button if you did that only the once, it should go back to the channel it was on prior to the "accident channel". I hope this helps, Jesus loves you, John 3:16-17 (KJV)
Jun 21, 2018 | Samsung Televison & Video
Hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Does the vibe 5 in 1 remote have a last channel button or how do you get it to go back to the last channel
Most remotes have a last or back button...Some even have flash button or arrow...Hope this helps
May 23, 2016 | Televison & Video
I need the steps to program the urc4021 remote, as well as the code for the sanyo tv
To program the One-For-All URC4021, first turn on the TV manually (or with the original remote). Press the TV button on the URC4021 once. Then press and hold the Set button until the LED blinks twice. Now you can enter a code directly and test it. For Sanyo TVs, the only programmed code is 0154 . If the LED blinks twice, press Power to attempt to turn off the TV. If that works, you can turn the TV on again and test if the other buttons on the remote work with your TV. If the LED doesn't blink twice, repeat the steps from pressing and holding Set. (If you wait too long before entering the code, the remote will leave the programming mode.)
The URC4021 has a code search mode. Press and hold Set until the LED blinks twice, then press 9 9 1 . If the LED blinks twice again, alternate between pressing the Power and TV buttons until the TV turns off. Then press Set to lock in that code and test the remote again.
I hope this helps.
(Note: if your TV is newer than the remote or released within 6 months of the remote being programmed, this code may not work. The URC4021 documentation gives March, 2004 as the copyright date. That suggests that the codes may not work with devices built in 2004 or later.)
Sep 29, 2015 | Sanyo Televison & Video
Pro-95 will not scan, when first turned on, unit goes to manual mode with last selected channel. Upon selecting SCAN, unit will switch to SCAN mode, but will not move off the bank of last selected...
If you did the hold down '2' '9' reset, there isn't much more you can do. I have tried pulling out the battery pack and putting in a jumper wire between both battery contacts inside the radio (with no battery) and turn it on and let it sit for 1/2 hour. That's about the last thing to try. Only other goofy thing could be you got 'sticky pop' on the 'manual' button, so the radio thinks you pushed the manual button as soon as you turn it on. Make sure that the rubber isn't stuck around the manual button. You could try a QTip with 70% alcohol around the edge of the MANUAL button, but you also might wipe off some lettering at the same time, so use caution. Good luck and let me know how it goes.
Apr 26, 2017 | Radio Shack Pro-95 Handheld Scanner
I Lost picture. Went to press mute button on remote and pressed last button instead. Now i can't get picture back.
If you hit the "last" button again, it should take you back to the channel you were on before you hit the button. when you lost the picture, was the screen blue? black? If you hit the "menu" button, does the menu come up?
Jan 11, 2013 | Vizio VW37L 37 in. LCD HDTV
My remote won't let me channel down past a certain channel, I can type the numbers in and it will go but if I try to arrow down channels it goes about 5 channels and then starts back over where it started,...
mp_383
What channels are you able to receive? When you press the Select button on DISH remote, which light on the top of the remote lights up? The Sat button should light up when you are in satellite mode. If any other button lights up, press and release the Sat button and then try changing channels. If this doesn't work, we may need to troubleshoot with you. Please call us on 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Mar 08, 2011 | DISH Network 135899 Remote Control
I can't find the jump button on my panasonic remote control. Is there such a button on the remote control which can jjump between two channel?
Should be a button on the bottom left of the remote labeled R-TUNE. That will send you to the last previously viewed channel.
Dec 24, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 09, 2009 | Televison & Video
Synergy V remote - TV power on to last channel viewed - what's the code??
Actually, there is a setting in the cable box for this. You hit the settings button on the remote TWICE, then scroll down to Viewer:Power On. Click on what channel (or last channel) you want it to go to when you power on. Hope this helps. I have the 8300 HDC DVR.
Oct 07, 2008 | Televison & Video
One For All URC-4021 Remote Control Logo
41 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
