Question about Intermec EasyCoder 3400 Thermal Label Printer
VB6 Runtime Error 486 when printing to an Intermec 3400e
I am calling form.printform and recieving a runtime error 486 "Can't print form image to this type of printer." Does anyone have a work-around or a solution? Thanks......
4 Suggested Answers
  • 18 Answers
SOURCE: Intermec 3400 label printer
try here they oft times has a few good referance materials
Posted on Sep 06, 2007
SOURCE: The Thermal transfer labels are
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Posted on Oct 01, 2010
  • 395 Answers
SOURCE: Intermec 3400E: Label prints
sensor and roller are first one you need to check to make sure they are still good to pick up the labels and feed them through
Label size and type are another one to make sure they work you this type of printer. If label is to thin, it will cause issue
Label stock may not be loading properly. Please make sure pay attention on this too
Update printer firmware and driver are the last steps. Make sure you have latest firmware and driver for this printer.
We have this issue once in the while. Most of the time label type and size are the causes
Let me know which OS you are using, i will try to find the latest driver for you.
Posted on Apr 26, 2011
  • 96 Answers
SOURCE: Dear Sir/Madam, Hello. we are using intermec
Check the media sensor for stuck label blocking part of the sensor. Clean the sensor with air if no obstructions are found.
Posted on Sep 23, 2011
0 characters
1 Points
Runtime error 91
UninstallSmart Panelvia Add/Remove Programs. Next download and install the DelReg patch from theNewsoft Smart Panel was manufactured for Epson by a third party company. As third party, licensed software patches and downloads are not on theEpson websitebut on Newsoft's own.
Patch for 1660 on Windows:
Run the patch, once complete restart the PC.
Next, reinstall Smart Panel from the CD-Rom. You may wish to update Smart Panel afterwards. Update Patches available below:
Copy Utility:
Smart Panel:
Photo Print:
Feb 27, 2014 | Epson TM-T88III Thermal Printer
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative.
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
for more information about
Device Type
Access Method
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Printers & Copiers
Dell AIO 942 Printer - updated driver from Microsoft
In this case you may try to change the print format of ur printer in order to do that please contact Dell at 1-800-WWW-DELL......
Good Luck........
Jun 05, 2009 | Dell 942 All-In-One InkJet Printer
Crinkled ribbon
Try adjusting the head tension or ribbon tension.
May 19, 2009 | Intermec EasyCoder 3400e Thermal Label...
Printing labels
Error 23 is "Image not found". You could try to increase the Image buffer size (in the front panel, "Setup, Service", "Memory Alloc", "Image Buff Size". I'd try to decrease the Rec and Trans buffers by 50kb to make 100kb available to add to the Image buf.
Sep 20, 2008 | Intermec EasyCoder 501e Label Printer
Can't get all-in-one center to work
bin the printer and do not buy from dell again
Apr 28, 2008 | Dell 962 Photo All-In-One InkJet Printer
Says driver not installed, gives runtime error
Download this program and run it:
Couse i think it can be registry problems
and run CHKDSK /R then restart pc
If u got help please rate this solution as FIXYA
Nov 20, 2007 | Dell 962 Photo All-In-One InkJet Printer
Intermec EasyCoder 3400 Thermal Label Printer Logo
286 people viewed this question
Top Intermec Printers & Copiers Experts
Paul Bade
Shahzad  Waseem...
Shahzad Waseem...
Level 1 Expert
Are you an Intermec Printer and Copier Expert? Answer questions, earn points and help others
