Question about Pioneer SD-533HD5 53" Rear Projection HDTV
SD533HD% Rear Projection TV wont turn on
My TV wont turn on. When you turn on the Stand BY button, it goes right back to red. I saw an answer with the fuse descriptions for this TV, but cannot find it now. Do you know what they are?
  • ANNABABY Jan 07, 2008
    SAME PROBLEM . OUR TV JUST SHUT OFF WHILE PLAYING A GAME. STAND BYE RED LIGHT ONLY COMES ON BUT THE TV WONT TURN ON. I WAS THINKING IT WAS A FUSE TOO PLEASE HELP. THANKS ANNA
    Problem Solver:
  • 13 Answers
You may need the power supply board resoldered as I had the same problem. The guy listed below can do it for you as I shipped mine from Illinois to him in California... Piece of cake getting the board out of the back and it's not too fraigile... Just pack in bubble wrap and it will be fine. My TV is now working great.
BUT DON'T DELAY AS SOONER LATER TV WILL NOT RESTART..
http://www.avsforum.com/avs-vb/showthread.php?t=402397&pp=30&page=38
Good luck.
cell
Posted on Jan 16, 2008
    Problem Solver:
  • 6 Answers
Mine has the same problem. I found out that it is a common problem. THe chipset STK392-110 (2 ) will go bad sooner or later depending on usage . The more you watch, the faster it goes bad. Pioneer recommended to replace them with chipset STk392-180 ( 18 watts ) . It is a doable job to replace the chipset but use the solder iron no more than 25 watts. It is not too bad. ALso look to replace any burnt resitors, blown up caps or fuses.
Good luck...
Posted on Jan 08, 2008
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung rear projection tv wont turn on.
Replace your STK ics both of them. STK392-040 go by number on parts
Nov 15, 2008 | RCA D52W19 52" Rear Projection Television
Will not come on
Sounds like a problem with the stand by votages. Possibly a low voltage regulator. Is the model number a 43H70?
May 03, 2008 | Toshiba 43H70 43" Rear Projection...
Tv wont turn on after fixing convergence problem
Check the pins with a strong magnifying glass to make sure they are solderd correctly with none of the pins bridged with solder, then recheck all the wire connections to make certain they are correctly hooked up.
Apr 16, 2008 | Samsung HC-P4752W 47" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
248 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
