Question about Ricoh Aficio AP3800C Laser Printer
Toner problem Hi, I recently posted this problem and solved it, or so I thought. It has now returned. The display says that toner is almost empty; which it is not. This only happens with the cyan. The black recently ran out and I replaced it with a new one which worked perfectly, so the problem would seem to be specific to the cyan only. Any ideas as I cannot print colour at all once the Add Toner message appears.
Yes, I am using OEM toners.
Posted on Dec 29, 2007
  • Ricoh Master
  • 1,113 Answers
R u using gen OEM toners?
Posted on Dec 28, 2007
Why printer squeaks
There are several moving parts inside the printer. more in a color laser printer.
Generally if you have used a refilled toner recently (any color or black), the chances are that the wiper blade in NOT seated properly inside the toner or reversed.
Try the following steps.
1. Set known set of good toner (even if nesrly empty)
2. Perform self test
3. Replace one old toner with new set corresponding color and eliminate which toner causes the squeak..
4. Mark that toner defective and Return.
5. If that is not feasible, try to forcefully rotate the drum in the opposite direction to see if helps flip the rubber blade in place
6. I will not suggest you to open the toner as it can damage the drum, spill toner and lead to you bigger mess.
7. If it is not due to toner, then the culprit is in the several gear trains inside the printer and that can be tricky to solve.
Sep 06, 2016 | HP Color LaserJet Pro 200 M276nw
Hi mi sumsingcxs6345nis tuner error
See the section on Replacing the toner cartridge in page 10.3 of the manual.
When the toner cartridge is completely empty:
• Toner Empty, Replace Toner1 appears on the display.
• The machine stops printing. Incoming faxes are saved in memory.
At this stage, the toner cartridge needs to be replaced.Check the type of the toner cartridge for your machine. (Page 12.1)
There are many well explained steps in the manual.
Mar 07, 2016 | Office Equipment & Supplies
How to solve CRU Fuse error ?
Check the TONER Cartridge and Reinstall it
CRU Fuse Error
Means : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]”
message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button < or > until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button < or > to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Jan 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Black Toner issue
Does your toner cart have any little clear plastic windows?
HP printers shine a light through this window to ***** toner level.
Cover one of the windows with tape & the printer will think the cart is full.
Sep 03, 2009 | HP LaserJet 4600dn Color Printer
Displayed error
1:you have to replace the drum unit.
2:open the drum unit & open waste toner cap &remove the waste toner & close the cap&insret the drum unit into m/c .problem solve.
Jan 13, 2009 | Canon imageRUNNER 400S Copier
Canon Fax L100 - toner required even though not empty
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
May 19, 2008 | Canon FAX L-120 Plain Paper Laser
Toner Is Almost Empty
When you changed the toner bottle, did the cap come out with it? Sometimes the cap gets stuck in the claws that open it up. Remove the toner assembly carefully, and look at the round end with the handle, where the bottle fits in. You should see a set of claws or fingers.
Feb 25, 2008 | Ricoh Aficio 1018 Printer
IntelliFAX 4750 Toner Empty
Hi, have you changed the drum anytime soon? If so did you clear the message before installing the new drum? The only other option would be to try a diffrent toner. There is not toner reset counter like there is for the drum! So I would reset the drum counter and see what happens. Good Luck
Nov 08, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Ricoh Aficio AP3800C Laser Printer Logo
208 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
