Question about Epson Stylus Photo R220 InkJet Printer
Epson RX220 message reads there are parts in your printer which need replacing Where do I get these parts ( believe this means an inkpad) and how do I fit them
    Genius:
  • 2,985 Answers
Generally you cant get the parts
One place to try is www.dot fixyourownprinter.com - if your are in the USA.
Amethos of overcomin this problem is this.
Go to the Web site above anf look up your printer in the Epson forum
Here you will discover how to rest the counters.
another way is to download the Epson Utility from www.ssclg,com.
On the bakc the printer to the left there is alittle door held by a screw.
trmove this and inside if you rake around on the left you will find a little tube.
carefullt lift it[dont puul] so that it hangs out of the door. find a length of fine polythene tube[Fishtank airline is just the right size] anf cut a lengt fit it over the printer tune[you may have to widen the end with a screw to get a fit] now find a suitable container or bottle and direct the tubs into it.
Now when the printer does a head clean it will fill the container.
Remove the container from time to time and discard the accumulated ink
Dont try to reuse it.
Posted on Dec 28, 2007
Tip
Tips for the epson R300
<br /> <a href="http://www.fixyourownprinter.com/forums/inkjet/68993?rate=1&ing=p"></a><br /> The message on your printer saying that "some parts have reached their life expectancy" or "service is required" followed by a shutdown of the printer has caused many people great anxiety. Some users have even sworn never to buy another inkjet printer from the manufacturer. If you interpret the message to mean that the mechanical parts of the printer have worn out, this feeling is normal. After all, who wants a printer that wears out when maybe only two years old? The message really should say, "The ink waste pads are full and must be replaced." With the Epson, R300 printer the problem can be solved as follows: <br />1. You can buy a new printer. <br />2. Reset the inkpad counter to zero by holding down both the Power and Stop buttons for at least 10 seconds. Then redirect the waste ink to an outside receptacle. Open the panel located on the right hand side of the back of the printer near the serial number location. It is held by a single screw. The ink waste tube can be fished out of the printer through this opening and lead into an outside receptacle. You will never have to replace the inkpads. <br />3. Reset the inkpad counter as above. Take the printer apart and replace the inkpads with new pads, if you can buy some. If you can't buy new inkpads, wash the used inkpads with soap and water. Let them dry and put them back in the printer. You can also replace them with absorbing materials like Huggies, Kotex, etc. <br /><br />Fortunately, I chose the first method before becoming aware of the other solutions. Buying a new printer is actually cheap and this is probably due to the manufacturer's desire to keep you as a customer. At the Epson online Store, under refurbished printers, I bought an Artisan 50 printer for under $60. When you figure that six new ink cartridges come with the printer and you don't have to buy inkpads it is essentially free. In addition, the new software is better than that on the R300 and the CD/DVD tray is smoother. The software is also compatible with files made by the R300. <br /><br />Since the R300 was no longer needed, it was used to look at the other methods for solving the inkpad problem. <br /><br />The second method was the cheapest and quickest solution. However, it potentially has a disastrous problem. The ink waste is pumped through the plastic waste tube by compression of the tube. This puts motion on the ink and it is unbelievable how easy it is to have the ink leave the receptacle. If this happens, clean up any ink spill with Resolve carpet cleaner. In addition, if you have kids or pets the ink receptacle may not always stay where you put it. <br /><br />The third method is NOT recommended unless you just like to take things apart or have other problems, like a clogged ink head that requires the removal of the ink carriage. See the PDF on web site. <br /><br />Every time a site was found that purported to have a service manual for the Epson R300 printer it couldn't be delivered, even for a steep price. Therefore, I decided to make a "Take a Part" document for the Epson R300 and try all of the methods shown above for inkpad and other repairs. This "Take a Part" document is available as a PDF.I will be pleased to email it to you. I am not a printer technician so please forgive any errors in nomenclature. The photos should identify the part. <br /><br />Washing the inkpads for reuse is, in my opinion, the worst operation imaginable. DON'T DO IT. If you can't find new inkpads, use one of the materials mentioned above to replace them. In the "Take a Part" document, two layers of Moddess Hygiene Pads are shown as the substitute. Do not take the pads apart, but be sure the bottom layers are placed with the water resistant layer side down and the upper layers with the water resistant layer side up. There are certain parts of the printer that should not be disassembled if you only want to change the inkpads. These include removal of the ink carriage and its shaft, removal of the waste ink pump, and removal of the CD/DVD print mechanism. <br />
on Jul 15, 2011 | Office Equipment & Supplies
Tip
EPSON PRINTER INKPAD RESET COUNTER
There are issues on printers especially with epson is the dreaded error " PARTS INSIDE YOUR PRINTER IS AT THE END OF ITS SERVICE LIFE"<br /><br />This error is caused by a full ink pad or the ink pad reset counter needs to be reset.<br /><br />to resolve this, for north american customers you can download a program called the inkpad reset counter. this is the site: http:www.epson.com/ipr<br /><br />from there just fill out the required spaces then submit. install and follow the wizard. make sure that your printer does not leak because it means you need to replace the ink pads. and its another question.<br /><br />hope this works and help you out<br />
Does any1 know how to reset the inkpad message on\...
You need a program,
R360 Inkpad/page counter Resetter
Call me and ask
entangled@bigstring.com
May 20, 2010 | Office Equipment & Supplies
PRINTER PARTS AT END OF SERVICE LIFE -ERROR MESSAGE. WHAT COULD IT BE? HOW DO I FIX IT?
that only means that the inkpad of your printer is already soaked by dried inks, this inkpad is the part of the printer is like a foam that absorbs excess inks when your printing, doing head cleaning, and head alignment, when it is soaked, the rprinter will stop working cause it can affect the output or print out, unfortunately, the inkpad is not a user replaceable part so either you go to service center, so they can replace it or better yet call epson if your printer is till coverd by 1 yr warranty, they should send you a replacement printer. thanks.
Feb 16, 2010 | Epson Stylus Photo R300 InkJet Printer
I changed ink cartridges in my epson stylus Photo RX620 and now thr window is telling me "Parts inside your printer are at the endof their service life.See printer documentation for details." I cannot...
that only means that the inkpad of your printer is already soaked by dried inks, this inkpad is the part of the printer is like a foam that absorbs excess inks when your printing, doing head cleaning, and head alignment, when it is soaked, the printer will stop working cause it can affect the output or print out, unfortunately, the inkpad is not a user replaceable part so either you go to service center, so they can replace it or better yet call epson if your printer is till coverd by 1 yr warranty, they should send you a replacement printer. thanks.
Feb 15, 2010 | Epson Office Equipment & Supplies
REACHED END OF SERVICE
Feb 10, 2010 | Epson Office Equipment & Supplies
I recently replaced an ink cartridge on my Epson stylus C66 and now the ink light and paper light are flashing on and off in turn and I can't get the printer to work. Do you know if there's an easy way to...
yes, this means that the ink waste counter is already in its peak and you need to reset it. try to download the inkpad reset utility through your computer. you will know all of the details from there on once you read them.
it would be www.epson.com/ipr
Sep 23, 2009 | Epson Stylus C66 Inkjet Printer
Epson Stylus CX5500 error message
actually i dont have one, sorry it took me awhile to reply check this website though and look for the utilty- printer reset utility- and check on the model number it supports:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Thanks for using fixya!
Jun 22, 2008 | Epson Stylus 2200 InkJet Photo Printer
EPSON PRINTER R22O
Hi-
yes actually there is. the parts its talking about is the inkpad, you can send this over to an epson certifies servicer in your are to have inkpad change and they will reset the counters for it. go this link and look for a servicer near your place
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
or you can contact epson at 562-276-1300
pls rate as fixya if helpful. thanks!!
Jun 21, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus Photo R220 InkJet Printer Logo
207 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
