Question about Compaq Business d530 (PB185US) PC Desktop
MIssing mother board driver
I recently got a used computer, and I had to replace a bad hard drive, Now I try and restart my system it freezes, I can turn the system off and turn it back on but when I hit restart, It shuts down ok but It wont reboot
    Genius:
  • 1,601 Answers
Sounds like a hardware conflict.
Try setting the BIOS to default...
Posted on Dec 28, 2007
A885GM-A2 new mother board will not boot up screen
You are missing the driver for the monitor. It should have come up but sometimes all the drivers are not or do not activate. If you have a disc for it run it and try to activate the monitor. It could also be the type of hook up you have. Make sure the cable is connected in the right port and that it compatible with your monitor. Might try the user friendly controls on the monitor. Make sure the contrast or black and white settings are not blacking the monitor out. Then there is always the possibility that you have a bad MB. Everything can work and it have a bad monitor driver as a matter of fact I have seen a lot of new and especially refurbished boards that were missing drivers. Also if you have the disc for the monitor you may have to run it again and it should program itself to the MB. Sometimes that has to be done. I have two monitors an Acer and a Dell and every time I have a hard drive go out I have to reprogram the Dell monitor. Try these things and let me know what results you get.
Later-
z
Mar 17, 2014 | EliteGroup ECS A885GM-A2 (V1.1) AM3 AMD...
I have a k8m 800 mother board with amd processor 1gb ram 500gb sata and LG sata dvd writer, my system is not working it is restarting. it is working only under safe mode. attemting to reinstall xp, first...
I would suggest that after windows copy all the driver in to your hard drive, instead of choosing a new or fresh installation you choose the letter "R" for and then 1 for the directory. Windows will attempt to recondition or reinstalled missing system files.
Sep 17, 2011 | ASUS K8V-MX Motherboard
Windows xp was deleted by accident when adding a new hard drive. I reinstalled windows software but nothing is working. It says the master file is missing. What do I need to do? I had someone look at it...
Joe is right on!
I highly DOUBT if your mother board is bad! Your VAIO was working ~ the software got deleted and now it's not working...
I suspect your Windows XP and DRIVERS need to be reinstalled. I also suspect you will have no other 'hardware' problems because it seems highly unlikely both would get trashed at the same time...
ALSO... XP came in 32 Bit and 64 Bit versions... be SURE you have the correct version for your System!
I provided a link for your VAIO drivers below.
Anthony
Sony VAIO Driver
Nov 27, 2017 | Sony VAIO VGC-RA840G PC Desktop
I have a acer aspire T180 desktop , on vista , and it dosent start up , when I go to the system recovery options , it says if you dont see your operating system listed , click drivers toload drivers for...
Most times when you see this message it means your computer can not see you hard drive when booting. I am having same problem and i my case is mo mother board has issues with SATA ports. You can try to replace hard drive cable and also try testing it in another computer. other than mother board this can be also hard drive it self. Test in another pc to determine is it or not. If no other pc by a docking station or hard drive enclosure and use it as usb external drive and see can you access it.you can use any computer even your friends. Hope this helps.
Apr 24, 2010 | Acer Aspire™ T180 PC Desktop
Motherboard missing drivers
Drivers aren't available for download from eMachines for this model. But the download page at Intel for the chipset used should have the drivers you need. Computer makers sometimes get custom versions of drivers, but the generic ones from the motherboard manufacturer usually work as well.
Jun 13, 2009 | Intel Desktop Board D845EPIL Motherboard
Seagate FreeAgent Pro - 500GB No detection need drivers
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive should be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
Also if you still need driver:
This is the best way to download the drivers of all your devices which are connected to the system for free.
You can download the Driver Magician from this link :
http://www.toggle.com/lv/group/view/kl34858/Driver_Magician.htm
Download the reg key from this link :
http://public.box.net/paul123
then doule click & select ok.
Run the program and select update drivers, it will list the list of pdated drivers.
Select the drivers and select download drivers.
If it does not download just select the driver you need and at the bottom you would see a link,
Just copy that link and download from your browser or download manager, I use orbit downloader.
Good Luck.
Live, Love, Laugh.
May 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
PC RESTART ANY TIME
Important Note: Only a computer professional should perform assembling, disassembling, upgrading and troubleshooting computers since the electronic devices may cause serious damage to the installer, the system, or its components if it is done improperly. Before attempting to disassemble or assemble computers, install components in a computer or troubleshoot computers, carefully review the documentation specific for the computer and its related components. Lastly, make sure to follow Electrostatic Discharge (ESD) procedures.
  • Determine if the system worked before. Determine if there have been any recent changes. Often if a recent change is been made, the recent change is the cause of the problem.
  • Check to see if your system feels warm and check the processor for overheating. NOTE: Use extreme caution when checking for heat, since you can be easily burned.
  • Make sure that the power supply fan is running properly and any other external case fans are running properly. Make sure that the air intakes for the external fans are unobstructed and have at least several inches away from walls and other items.
  • Make sure the fans on the processor are connected properly and running.
  • Make sure that the thermal interface material or the thermal grease is applied properly.
  • Disable thermal measurements and power saving features in the BIOS setup program.
  • Update the system BIOS to the newest version. In addition, check to see if your system has a firmware that could also be updated to the newest version. Refer to your motherboard documentation.
  • Check the BIOS using the BIOS/CMOS setup utility, particularly the boot order. Make sure that your system is detecting all of the drives and make sure that the drive you are trying to boot is listed.
  • Do not overclock your system. Your system can become unreliable, may shorten the life of your PC components, may damage your PC components and may void your warranty.
  • Check the BIOS using the BIOS/CMOS setup utility, especially the RAM settings.
  • Suggest running ScanDisk to see if your hard drive has a lot of lost clusters and other anomalies. If you don't properly shutdown your computer using the Start button shutdown option, you may see some lost clusters and possible bad clusters.
  • Suggest running an updated virus checker to see if your system is affected by a virus.
  • Suggest reloading the OS, drivers or program.
  • Suggest reformatting the hard drive and reinstalling everything
  • Verify that your chassis/case and power supply is appropriate for the processor model and frequency and the motherboard you are planning to use. For Intel Pentium® processor 4 based systems, you should be using an AXT12V, SFX12V or PS3-12V power supply.
Mar 02, 2008 | Intel D865GBF Motherboard
Restarting
before it start to do that was the computer freezing it sound you haqve problem with thr mother board check you power bar good luck cheers
Jan 18, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Mother board problem?
re install touch pad driver and try again
Jan 08, 2008 | Toshiba Refurbished SYSTEM BOARD 400CS...
Restart the computer
Just check to make sure that the CD-ROM drive has all its cords properly attatched. It sounds like there is either a driver conflict of some sort or a power failire in your system causing the BIOS to restart the machine. Check all power cables and if you recently updated the driver to the drive, roll it back. If your problem is still not sorted, try disconnecting the floppy drive or something from the mother board and power, see if the power supply is being overloaded. Or, you may need to simply purchase a new CD-ROM drive, would probabaly be your best bet.
Jan 05, 2008 | Computers & Internet
Compaq Business d530 (PB185US) PC Desktop Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
