Home | GE | Nautilus 24" Built-in Dishwasher | There is water in the...
GE Nautilus 24" Built-in Dishwasher
Problem for GE Nautilus 24" Built-in Dishwasher
There is water in the bottom of the dishwasher.
By mdbianca on Oct 18, 2009
There is water in the bottom of the dishwasher. How do I locate the drain hose? Which one is it underneath the dishwasher?
Best Solution
posted on Oct 18, 2009
Very Helpful)
jan mczeal
Rank: Guru
Rating: 87%, 237 votes
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for GE Nautilus 24" Built-in
Questions and Unsolved Problems for GE Nautilus 24" Built-in
Do you recommend GE Nautilus 24" Built-in Dishwasher?
Answer
Answer
The water does't all go down, leaving residue on my dishes
Answer
my dishwasher doesnt seem to have enough water pressure to raise the funnel and circulate water. ... (More)
Answer
while running a cycle. The dishwasher stopped and the water did not drain out.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Nautilus 24" Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
