Question about Waring BB180 Work Top Blender
Waring blender BB180
Pitcher base is stuck to blender.
  • 3 more comments
  • MeinTX Feb 29, 2008
    Have a Cuisinart model that is a glass jar and a plastic base. Have tried: freezing the whole thing
    putting cold water inside while it is submerged in hot water
    pouring boiling hot water into the seal
    It's not budging. Please help.
  • Anonymous May 19, 2008
    Tried WD40 soaking in boiling water not budging ame thin Cuisinart glass on pitcer on plastic base
  • Anonymous May 06, 2009
    Our pitcher base is firmly stuck to base unit too. Any new suggestions? Thanks!
  • Anonymous Mar 17, 2014
    Waring PBB blender jar blades do not spin
  • Anonymous Mar 23, 2014
    Blender base will not unscrew from glass pitcher...?
  • 3 Answers
Try to soak hot water around the base unplug firts and pour hot water slowly at the base
Posted on Jan 01, 2008
The black plastic screw on bottom of the pitcher is stuck on the base. We can't seem to get it off. Have any hints
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Aug 20, 2015 | Blenders
Pitcher stuck on base
You will likely need to replace the beaker anyway, the drive which is now melted to the motor coupling is only supplied as part of the beaker/blade assembly. You will also need a motor coupling.
Aug 01, 2012 | KitchenAid Blenders
How do i replace clutch in base of blender
here is a solution that worked for me (see below) get the clutch out I used a flat-head screw driver in the bottom of the base to hold the cooling fan and then screwed the clutch out with a clockwise turn. I have yet to order a new clutch ($2.70) at but the removal works. Good luck.
There are two type of fittings for this gear. In some models it will be push in type, and for others it will be screw type. If your model has push type one, just pull out it from the shaft. You may have to excert a strong force to pull it out. If it is screw type, you have to open its lower lid by unscrewing its secrews, hold the cooling fan and hold the gear at the top, twist it in 'CLOCKWAYS' direction, [not counterclockwise], to screw it out. OK.
Mar 14, 2011 | Waring BB180 Work Top Blender
We have an old Waring Futura 900 blender that leaks at the bottom of the glass around the beater blades. How do you repair? Is there a gasket?
Yes their is a gasket. However try to tied the hole blade kit a litle harder since it might be loose, it might be also dirty you can loose it clean it and put it back.
Have a visual insections since the glass might be broken a litle bit also.
Good luck
Aug 09, 2010 | Waring BB180 Work Top Blender
I can no longer unscrew the plastic part that the glass container fits into on my old Waring 18BL28 blender. It is a simple 10 speed that works perfectly.
Something sticky is in the threads... Try very hot water in the sink as a start, while boiling some water on your stove. With the glass and plastic preheated, install them to the blender base which must be unplugged for the rest of this adventure. Pour the boiling water in, only to about 1/3 of capacity. Install the top cover to protect from the hot water. Hold the glass by the handle and with a rubber glove on the opposite corner or pour spout side. Hold high to avoid the heat from the water. Have a large burly man hold the blender base so that you may twist the glass container counter-clockwise. Stop as soon as it starts to turn the plastic ring off...and go the the sink... Continue after pouring out the hot water. Remember that his procedure is likely to cause broken glass or broken plastic and exposure to scalding hot water. If those risks are acceptable you should still take precautions to protect your flesh. Otherwise order a replacement ring and pitcher for the blender.
Dec 23, 2009 | Waring Blenders
The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Nov 12, 2009 | Waring BB180 Work Top Blender
Broken gasket can't find a replacement Waring NuBlend BB180 without buying the whole replacement blades kit. just need the gasket.
Go to They have all the parts. I have these blenders for my my nutrition club and this is the only place I have found parts at very reasonable prices.
Nov 05, 2009 | Waring BB180 Work Top Blender
Waring BB180 Work Top Blender Logo
398 people viewed this question
Top Waring Blenders Experts
Are you a Waring Blender Expert? Answer questions, earn points and help others
