Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Blue to Black screen on Sony KP-57WV600
I have a problem with Sony KP-57WV600: When I turn it on there is sound and a blue picture for about 10 seconds then the screen goes black, sound continues ok. There is a red light on the front panel that blinks 7 times. Any Idea what the problem is? I would appreciate any asisstance.
  • 1 more comment
  • KrisEverette Jan 03, 2008
    I have to same problem. Just happened the other day. Is it an issue or recall?
  • classic134 Jan 03, 2009
    My Sony KP-57wv600 goes from blue to black or stays on blue for 2 minutes when turned on. Then i have blue curved lines in the picture. What can i do to correct this problem. Thank you very much
  • Anonymous Feb 17, 2009
    I have the exact same problem.. 7 blinking lights blue to black picture. Any help is appreciated.
Rowdyroddy,
Thanks you so much for this info.
I had the same problem with my Sony KW-57wv600. Blue screen turns black after a few seconds, and then standby light flashes seven times.
I called a local TV technician, and described problem. I was told it would not be cost effective to fix. After reviewing the "simple" instructions given on www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html I figured I had nothing to lose.
10 minutes to remove front panel, a "very slight" turn of a screw, and TV worked again perfectly. I could not believe it!
Thank you so much for your help!
SHAME ON SONY FOR NOT POSTING THIS FIX ON THEIR WEBSITE! SHAME ON THE TECHNICIAN AT SONY WHICH INSISTED A SERVICE TECHNICIAN WAS REQUIRED.
I have always been a fan of Sony, swearing by Sony products exclusively. After this experience, I am now forced to consider some other options when purchasing electronics in the future.
Posted on Mar 04, 2009
    Problem Solver:
  • 7 Answers
I too have 57wv600 and your problem is same as mine VOLTAGE withen tube is off ...this is common problem sony knows full well and will not tell us this voltage can be adjusted with a philips screwdriver i had blue lines then solid blue then shut off...7 blinking lights ...went to this site followed directions (too simple)and now i have perfect picture.serviceman said i needed new tube.b.s. ...so never change your tube it is not the prob!!!!!!!....go to www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html read post(comment) near bottom of page by paul t dated 12/26/2007 and instructions on how to remove our front panel is fully explained ...a screwdriver will fix your problem I guarantee it.....
Posted on Jan 24, 2008
  • 3 Answers
I have a service manual for this TV with all the board layouts and lots of info. I am willing to share if someone can help with this problem. So far I have only been able to determine that I have the same problem, that either 1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
Posted on Jan 17, 2008
  • TaoHawaii Jan 17, 2008
    P.S. The overcurrent is detected by too much current flowing throught R5013.
Sony projection tv turns to a blue screen almost immediately and then turns black seconds after that.
Hello, it sounds like the blue crt has a cathode short in it and causes an overdrive situation putting the set into shutdown. The crt's are no longer available.
Sep 17, 2014 | Sony KP-57WV600 57" Rear Projection...
Sony Projection TV problem
sony rear projection KP series are know for having bad utbes after while..ihad seen the blue tube goes on most.
Jan 22, 2010 | Sony KP-57WV600 57" Rear Projection...
I have a Sony KP-57WV600 projec. have picture for 10 seconds then screen turns blue for 10 sec.then black and I still have sound red light does blink but I dont know how many times. Called Sony they told...
You have a shorted blue CRT (picture tube)
The problem is that these TVs are known to have defective CRTs but Sony can no longer supply them. There is a company in Texas that rebuilds them, but its an expensive repair.
Its a shame that Sony has not been forced to take care of their customers. I've replaced hundreds of these CRTs and seen hundreds more after the supply ran out.
Sony knew about this issue way back in 2002 but only resolved complaints for a limited time and did nothing to notify owners whom they could easily indentify by serial number.
Let's hope we don't give up our auto industry or we'll soon see the same behavior there.
michtech
Feb 19, 2009 | Televison & Video
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Dec 25, 2008 | Sony KP-57WV600 57" Rear Projection...
TV going to from blue to black
You both have a bad high voltage Trippler block.
Apr 30, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP 57WV600
how many times does it blink?
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 screen
I had the same problem except blue lines then all blue..I needed a blue crt tube..........so I'm assuming you will need a green crt tube
Jan 14, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
1,533 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
