Amana ALW880WH Top Load Washer
Problem for Amana ALW880WH Top Load Washer
My top load ge machine does not spin. it fills
By god2angels on Oct 18, 2009
my top load ge machine does not spin. it fills with water and makes a humming sound like it is trying to spin. how can i get it to work
Solution #1
posted on Oct 18, 2009
Not Rated)
jan mczeal
Rank: Guru
Rating: 87%, 250 votes
GE washers usually use a clutch to come up to the proper spin speed. If the clutch wears out, it prevents the unit from spinning well or at all. If so, you need to replace it. You may need the service of a qualified appliance repair technician to do the job.
Was this helpful?
Yes
No
Solution #2
Not Rated)
hiltonjug
Rank: Guru  Washers & Dryers  Expert
Rating: 92%, 204 votes
Sounds to me like the belt has either came off or has broken. You can remove the front lower panel to see if the belt is still intact.To remove, put a hand on each side of the panel toward the top. Pull toward you, the top of the panel will un-clip and pull out. Then just pick up on the panel and set aside. Now look for the belt. Pull on it and make sure it's tight. If not you will need to reinstall it of if broken, replace. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Amana ALW880WH Top Load Washer
Questions and Unsolved Problems for Amana ALW880WH Top Load Washer
Do you recommend Amana ALW880WH Top Load Washer?
Answer
Answer
My washer (ALW880QAW) agitates but does not spin. I took off the front cover and the found a black... (More)
Answer
no pressure coming out of cold water faucet. cannot unscrew hose. workmen were working on water line... (More)
Answer
Our Amana 2002 top loader washer model ALW880QAW is leaking from the transmission to the tub, where... (More)
Answer
It won't spin out fast enough which leaves the clothes dripping wet.
Answer
Motor S68pxmcm-1069 not turning the right direction. Noticed on spin cyle, loud clicking.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Amana ALW880WH Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
