bought a new dometic a/c and it won't run. voltage is present in the control box until the upper unit is plugged in/connected, to the control box/thermostat. the voltage to the upper unit then disappears like it's shorted or grounded.
prior to plugging in the upper or main unit there was 110v a/c present
on the lo and hi fan terminals as well as the output to the female
plug for the roof unit. when plugged in the 110v is no longer present on any terminal of the control box or thermostat.
any idea what may be causing this problem?
Joel from Florida
My RV roof top air conditioner has no power going throw the circuit board needing to replace the...
(More)
My RV roof top air conditioner has no power going throw the circuit board needing to replace the circuit board .
model 59516331G9 on the comfort control center digital screen will show temp set for a short time...
(More)
model 59516331G9 on the comfort control center digital screen will show temp set for a short time the show E-4 this goes back and forth fan will come and go off. The controls come on for furnace or coll but still show the same notes
a/c and furnace wont work.I have a duo therm, model #59516.531 on my toyhauler with a 3107541.009...
(More)
a/c and furnace wont work.I have a duo therm, model #59516.531 on my toyhauler with a 3107541.009 thermistat... The a/c-furnace switch when selected does nothing..cant even hear the relay board clicking.. but the fan works fine..High and low. I have checked the fuse in the relay box and circuit breakers on panel and on onan genny.. dont know of any more?
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a...
(More)
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a Duo therm roof top Penguin model
had loft conversion, problem on inside of picth roof where roof meets floor gets wet and patches...
(More)
had loft conversion, problem on inside of picth roof where roof meets floor gets wet and patches above velux windows and elsewhere appear, the builders did leave a ventilation gap inside the rafters before installing celotex, we have old type felt
