Question about LG WM-2277HW Front Load Washer
Samsung p1253 LE code appears halfway through the wash and the machine has to be reset. It then normally works. Same thing happother wash. Any ideas, please?
  • missmia Jan 09, 2008
    I have tons of problems, my clothes smell foul and I have an LE code flashing as we speak. I can feel some resistance when I try to turn the drum but then nothing it still cuts off after about 12 minutes....
  • 283 Answers
LE means locked rotor or overload in motor. Check for binding or mechanical resistance. check motor winding resistance. Also check 3 pin connector in motor harness, harness between stator and main board or Hall Sensor on motor could be defective
Posted on Dec 28, 2007
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    LG WASHER LE CODE
    Fix for Error Code "LE" on LG Front Load Washing Machine
    I just had an interesting experience with our LG washing machine today. I found some hints for the solution online buried in some user forums, but I thought posting my particular solution here in a less cluttered blog might make it easier to find.
    I had just run a load of laundry, emptied the machine, and reloaded. I put the detergent in and started the machine. After sitting for about 2 minutes with no activity, a "LE" error message appeared.
    While the online forums indicated this might be a problem with a sensor, I was able to solve the problem by doing the following:
    1. Press the Power button
    2. Manually rotate the hopper 4 times clockwise and 4 times counter-clockwise.
    3. Press the power button and run the machine normally.
    Don't know if this will work for everyone, but it worked for me. If I keep getting the error message, I'll have to call LG and find out about this sensor I was reading about.
    May 30, 2014 | LG WM-2277HW Front Load Washer
    Hi,i have a samsung washing machine,p1253.model and i keep getting a code UE,and it appears not to be spinning.....please advise what this code means and is it possible to read an instruction manual on...
    Hi, UE error means unbalanced load, loosen the washing and try again, if the load is to heavy take out some of the washing and spin in 2 lighter loads.
    UE Happens if you overload the washing machine.
    CLICK HERE for the user manual.
    Hope this helps.
    (Dont forget the thumbs up if this helped)
    Feb 12, 2011 | Samsung Washing Machines
    Le code appears during normal cycle
    LG recommends unplugging the washer for 15 - 20
    minutes to reset the microprocessor.
    The most common cause for the LE error code is over-sudsing in the machine from using regular detergent instead of a high efficiency detergent. The HE detergents are designed for lower suds levels and enhanced cleaning performance in front-loading washers.
    Overloading the wash with too much laundry may also cause the LE error code. LG recommends loading the washer until the clothes in the drum are no more than three-fourths of the way up the window of the door. This will allow them sufficient room for tumbling.
    http://tclaundryrepair.com/
    Feb 26, 2009 | LG WM1814CW Front Load Washer
    Samsung p1253 hole in outter drum,what is it made of and is this a common fault?
    Hi I take it that the outer drum is made from plastic the only thing that would cause this problem is a large coin got into the drum and as the machine was spining the force made it hit the outer drum and chip it making a hole
    Jul 18, 2008 | Samsung Washing Machines
    Error code LE
    Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
    May 27, 2007 | LG WM2077CW Laundry XL Front Load...
    LG WM-2277HW Front Load Washer Logo
    456 people viewed this question
    Top LG Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
