Shuts downs HI, My laptop shuts down randomly when in moddle of doing something. Most commonly happens when installing software of editing photos. Any suggestions Many thanks in advance
  • Anonymous Dec 02, 2008
    My laptop will shut off randomly. I will restart the computer and it may work up to an hour and shut down again.
  • 90 Answers
Sounds like an overheating problem. The hard drive spins and generate heat in software installation. Editing pictures loads the CPU that heats up. Make sure the laptop is well ventilated. Try to use a laptop cooler.
Posted on Dec 28, 2007
My laptop (lenovo g560) randomly shut down.
Try scanning your computer with radarsync to know which drivers are out-of-date. It has something to do with the device drivers for sure. Update the drivers using RadarSync.
If it still not going to fix the problem then check if there's a sign of overheating after it shuts down. You might want to get it opened by a technician so that he or she can clean the air passages and fans inside your computer.
David
Jun 30, 2013 | Lenovo G560 06793JU Notebook
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Jan 17, 2013 | Computers & Internet
Laptop randomly shuts down
Random shutdowns can be hardware or software related. General advice is as follows:
Go to support.dell.com and download the latest BIOS Flash, Video Driver and audio driver for your system and install them, once installed and rebooted see if the issue is resolved.
If not, start, run MSCONFIG, edit the entries in the startup group disabling all except antivirus entries, reboot and see if any change.
If issue no longer occurs, then you can add items back one at a time until you isolate items that cause the issue.
If the software editing has had no effect, try ram modules individually (System will operate on one) and see if issue is isolated to one module or slot.
Jan 15, 2011 | Dell Inspiron 1525 Notebook
Re my Thinkpad T61: Last weekend it froze. Icons would not respond to mouse clicks. Could not open new programs or close the programs that were open. Pointer was still working -- it just did not work to...
There are a couple of things that can go wrong with it. The most common thing on laptops is overheating.
You will know if your laptop is overheating if it happens one ore more of the following:
-The keyboard and the bottom of your laptop are very hot when the laptop is working.
-The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
-The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
-The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Follow this steps to avoid overheating:
-Don't use your laptop in full sunlight for extended periods
-Don't leave the laptop in a closed car on a sunny day
-Don't place the laptop on or near extreme heat sources, such as radiators, hot air vents
-Turn off your laptop before putting it in your carry bag
-Turn off your laptop when not in use for a long period
-Work on an even surface as much as possible, not on your lap!
-Clean the air vents in your laptop regularly by using a can of compressed air
-Get more space under your computer by propping it up on something when it's on a desk
-Consider purchasing a laptop cooling pad
-Consider purchasing an external fan
To clean your laptop's cooling system:
-Shut down the laptop ie do not leave it suspended, sleeping or hibernating.
-Unplug all cables from the unit and remove the battery pack
-Get a can of compressed air and blow it into all vents around your computer - this should clear out any dust and hair.
-Do Not use a vacuum cleaner
If it is not overheating, then it is a hardware failure. Could be the RAM memory, processor or the motherboard. You can test the RAM with this program: http://hcidesign.com/memtest/MemTest.zip
If RAM is ok, then only replacing hardware equipment could corner the problem.
Dec 15, 2010 | Lenovo ThinkPad T61 Notebook
I have a Compaq NW9440 Mobile Workstation - it keeps shutting down every 15 minutes or so. At times, it will not restart right away. I thought it may have been the CMOS Battery, so I replaced it. It's...
The most common problem you get with a laptop is overheating, this can cause for it to shut down while operating to prevent more damage.
-Do Not use a vacuum cleaner.
If it is not overheating, then it is a hardware failure. Could be the RAM memory, or the motherboard. You can only corner the problem by testing with different RAM modules or motherboard.
Dec 01, 2010 | HP Compaq nw9440 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
My 4 year old Acer Aspire 5520 notebook shuts off on me at random time periods. I try keeping it proped up and keeping it cool but that doesnt even seen to help. It doesnt over heat but just decides to...
Have you cleaned the cpu fan? The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. The other thing that could be happening is some problem with windows, which is something I couldn't begin to guess. Hope it's just a bit too much heat.
Mar 29, 2010 | Acer Aspire 5520-5908 Notebook
This problem might be occur due to old BIOS version installed on the laptop.
If your system shut down unexpectedly within 10-20 minutes while playing games or scanning the system which takes high cpu usages then the problem is of BIOS and try to install the new BIOS version.
for that visit the site of your laptop company.
Nov 25, 2009 | Computers & Internet
Hp laptop shuts itself down
Laptops are designed (by software) to shut themselves off as a protection measure. The most common problem is high temperatures. Do you hear your fan racing while you are using it? Do you sit your laptop on soft surfaces (like the bed or carpet floor) while using it? Do you smoke around your laptop while using it? These are common things that cause high temperatures on your laptop and will cause it to shut down. May not be your case but just a though. I would take it somewhere or open it up yourself(if you are pass your warranty time ONLY) and clean out the dusk with some air.
Hope this helps!
-Curtis
Rate It!
Jan 29, 2009 | HP Pavilion dv5-1000us Notebook PC
Computers & Internet Logo
503 people viewed this question
Alun Cox
David Payne
David Payne
