Question about Panasonic Televison & Video
Panasonic TC-22LH1 The connector on the TV where the HDMI Cable gets connected to is bad. There is no sound with the HDMI Cable connected. I am using the analog connection to get sound. Although the TV is a 2003 model, the HDMI cable was put in use 11/27/07. Panasonic advised me to get an estimate to repair the TV. What is involved and what will it cost? Thank you, Chuck Lipinski cdlipinski@comcast.net
SOURCE: HDMI problem
Set your 4:3 to stretch mode, see this link
www.hightdefforum.com/showthread.php?t=24734
Posted on Feb 04, 2008
Agent Aaron
  • 265 Answers
SOURCE: Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
SOURCE: Sound problem with Sharp LC-32D4U
I'm having the same issues
Posted on Jul 19, 2008
  • 33 Answers
SOURCE: sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Posted on Dec 12, 2008
valiantma595
  • 176 Answers
SOURCE: connecting Bravia to PC using HDMI cable
You did okay but the phono sockets are not for Computer/TV use. Phono sockets should be checked int the manual on why they're there. If you have connected the Bravia to your computer, using the appropriate cable, then you should also purchase or request from the retailer where you purchased the TV a cable that has stereo phono plugs and, you didn't say what size phono sockets they are but I presume they are 3.5 mm. So, if the TV has 3.5 mm sockets, you purchase a cable with stereo 3.5 mm plugs. This is adequate for the stereo wav sound coming from the computer and going into the TV. Remember, having 2 Phono inputs on the TV doesn't mean anything. The TV could have a number of video inputs too, ATD AVT, AV, COMPONENT1, COMPONENT2, HDMI1, HDMI2, HDMI3, etc. each have it's respective sound inputs for AV, S-VIDEO, DVD, Blue-Ray, etc. But for the computer there may be a different type of socket for it's sound inputs, normally it is the old phono sockets. Seek help from the retailer or else you could cook the circuitry of the TV's sound system.
Posted on Sep 18, 2009
What are the best settings for the DMP-BDT330 Panasonic Bluray Player
Hello Myles, we recommend you connect the player with a HDMI cable and then set the player's output to 1080p.
Apr 27, 2014 | Panasonic Televison & Video
I just bought a Sony sound bar ht-st7 I have a Panasonic tc-p50vt25 tv and and a Panasonic blueray player these products don't have ARC. I have been using the red white cable connected to my cable box the...
Your TV does support Audio Return Channel (ARC). Try connecting your Bluray player to HDMI 2 and your sound bar to HDMI 1(ARC). You will need to make sure that VIERA link is turned on in the Setup menu of the TV.
Aug 27, 2013 | Sony Audio Players & Recorders
Connecting a panasonic surround sound to a sanyo tv
if you have this option, use a hdmi cord from the dvd output to the input of the tv.most new tvs have several hdmi connectors. Then use a fiber optic cable from sound system to the audio input of the tv. between the both it should sound like a movie theatre. thats how i hooked mine up. good luck
Feb 27, 2012 | Panasonic Audio Players & Recorders
I cannot get sound when using an HDMI with my Panasonic Viera TC-L32X2 LCD. I have tried three different HDMI cables, I'm highly confident that is not the problem. My cable provider had to override...
Is this TV new or new to you? I suggest you check two parts of the Audio > Advanced Audio menu. First check if the TV speakers are set to on. Next check the HDMI audio setting. This should be set to Digital. (There is an analog option that works with DVI to HDMI cables and older HDMI cables that aren't fully HDMI compliant. For these situations, you connect an audio cable between the cable box and TV. I believe your audio cable needs to have a 3.5 MM (M) end at the TV and plugs in at the computer audio input.)
Since your cable provider turned off the HDCP (high definition copy protection), it's possible that the cable box is treating the cable as being incapable of carrying the audio. Try using the Analog audio option, described above. You may want to check if your cables are fully-compliant with the HDMI specification (and HDCP). Then get the HDCP enabled in the cable box. Similarly, check the audio output settings for the cable box. (If you can access the Settings for the cable box without a service call, you should look at the Audio and Display settings. My cable box has Display options for HDMI versus DVI cables, as well as a choice for Digital Audio for the HDMI option in the Display sub-menu.)
I hope these ideas help. If you need more information, add a comment with the settings for your Audio and Display settings. The manual is available on the TC-L32X2 support page, http://shop.panasonic.com/support-only/TC-L32X2.html . The direct link to the manual is currently ftp://ftp.panasonic.com/television/om/tc-l32x2_en_om.pdf . See page 28 for the Audio menu options. Since you tried three cables, I think the odds of all three being bad is slim.
Nov 01, 2017 | Panasonic TCL32X2 32 in. HD-Ready LCD TV
How can i watch my computer on my tc-32lx700
It depends on your computer's outputs. If you have an HDMI output, all you need is an HDMI cable. Note: There is a huge markup on HDMI cables so look around to find a decent price. You can get a 12 ft cable for about $30.
If you do not have an HDMI output, you will need a slightly different setup. There is a good article here: http://www.geekwithlaptop.com/how-to-connect-laptop-to-tv
PC to TV converters are about $40, if you end up needing one. I used one for quite a while until I got a laptop & tv with HDMI.
Nov 02, 2009 | Panasonic TC-32LX700 Television
Broke HDMi connector on TV
If you are talking about the part connected to the tv, you need a new part. Investigate ! In the meantime use a S Vidio plug, or the red, white and yellow cables to get you going.
Sep 19, 2009 | Televison & Video
Trying to connect my Asus laptop to my TC-32lx60 panasonic TV via HDMI
You must first verify that the VGA cable from the laptop to the TV is in good condition. You must also verify that the VGA connector on the computer, and the connector on the back of the TV are not defective. It can also be critical that the computer display output is set to a mode that the TV can use. Consult the user guide about the TV set for detials for compatible resolution settings from a computer.
Jerry G.
Oct 13, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Open Questions:
Televison & Video Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
