Bosch 3.81 cu ft Nexxt 500 Plus Series Washer - WFMC530 1UC / SUC / CUC / WFMC530CUC - Champagne Du
Problem for Bosch 3.81 cu ft Nexxt 500 Plus Series Washer - WFMC530...
Stops at spin cycle does not drain.
By sehwaila on Oct 18, 2009
stops at spin cycle does not drain.
Solution #1
posted on Oct 18, 2009
Not Rated)
ginko
Rank: Guru  Washers & Dryers  Expert
Rating: 89%, 5114 votes
Hi.
The first thing to check is the drain system. Check the drain hose at the back, and the drain pump. The drain pump can be tested advancing the cycle to drain. It can also be tested by a technician, energizing the pump directly.
The pump can be accessed removing the small service panel in front of the washer. Access to pump is located on lower right hand corner in front.
After removing the panel the pump is accessed and disconnected from hoses to remove the blockage in there. The procedure is also illustrated in service manual. Have a container ready to collect water if you DIY.
If the pump is OK other parts that can cause the problem, and that must be tested are the pressure switch, and the electronic control board.
Regards.
Was this helpful?
Yes
No
Popular Solutions for Bosch 3.81 cu ft Nexxt 500
Questions and Unsolved Problems for Bosch 3.81 cu ft Nexxt 500
Do you recommend Bosch 3.81 cu ft Nexxt 500 Plus Series Washer - WFMC530 1UC / SUC / CUC / WFMC530CUC - Champagne Du?
Answer
Answer
Sounds and feels like something - a screw? - is behind the drum. Bosch Nexxt 500 washer. Any way to... (More)
Answer
Need instructions to use a Bosch 500 Series washing machine. No manual came with it.
Answer
washer does not wash or rinse with cold water. When machine is set to wash with cold water just a... (More)
Answer
had code e 04. after clearing problem code e 02 comes on, any solutions
Answer
I have a Bosch Nexxt Front load Washer and using your posts was able to fix the E:04 error and clear... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
