I replaced installed additional RAM in my eMachine T4510 but it wouldn't complete POST. Removed the new RAM and re-installed the factory-original RAM and it still wouldn't complete POST. Removed all RAM and the keyboard lights flash, as does the FDD light, but doesnt complete POST or even beep that the RAM is missing; monitor never lights up during POST.I left EVERYTHING unplugged overnight, plugged in only the power cord, keyboard, and monitor (RAM still removed) with no change in symptoms, What do I do??
In your motherboard there will be a CMOS battery remove that battery and put it again you will get the display in your monitor, the battery will be in coin size the battery is CR2032.
will not start. makes a beeping noise. will sometimes start after several attempts. will not go to...
(More)
will not start. makes a beeping noise. will sometimes start after several attempts. will not go to desktop.
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. ...
(More)
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. I've tried using a repair program but it says the C: partition1 is unknown and cant use this area.
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm...
(More)
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm pretty sure it freezes. What should I do?
