Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Watts of the resistors convergence tbl
After changing the chips , I found my 3 resistors open for the JVC convergence problem, 220,2.2 150 ohms for the blue color , but they don't have the watts or volt info. I 'don't find a local store to buy also.
  • Anonymous Dec 29, 2007
    I hope you get this info. the numbers on the resistors board are R850, R873,R863, so i will need the information on those. I live in Boynton Beach FL and I don't find a store to buy them either.I went to mouser but I don't know the correect ones to choose
    thanks for your help
    Novelist:
    Champion:
  • 232 Answers
Give me the board location numbers and I`ll get you the info you need, (next to the resistors it will be printed on the board, )example: R100, R265, R565 etc. Let me know BMW Rider
Posted on Dec 28, 2007
Jvc av-48wp74
Yes, they are in pairs(look at the 1/2 watt ones) and you will see two identical pairs with one for each chip---if I remember this model they may be 1.8 ohm----only very low value resistors will pop----also there will or should be a pico fuse for each chip on that board---orange or green etc that looks like a resistor and they may (going from memory) be marked 3a or 3 amp----both the resistors and the possible fuses can be checked with a meter----no reading and bad.
Oct 31, 2012 | Televison & Video
Convergence Resistors keep burning up
Some simple advice---if resistors are smoking one of the chips is shorted----The set has two voltages that go to them--one a positive voltage and one a negative voltage.
If either chip is shorted you can replace the resistors all year and not get anything. The resistors are protection in case one or both chips short----
Remove all old heat grease and install two new chips and replace the resistors at the same time.
Note that the set may have pico fuses on the power board also.
Jun 09, 2012 | Sony Televison & Video
I have a Hitachi 43fdx01b and I have just replaced the two convergence chips because of a "Red" convergence issue. I learned the hard way about the desoldering and resoldering, but got it done. Now i...
did you check the resistors by the convergence chips? check to see if they are open. the resistors are usually lined up on the other side of the heatsink as the convergence chips.
RK42 2.2 ohm 1 Watt
RK46 1.5 ohm 1 Watt
RK50 2.2 ohm 1 Watt
RK54 1.5 ohm 1 Watt
RK58 3.3 ohm 1 Watt
RK62 1.8 ohm 1 Watt
the convergence chips to be used are
IK04 STK394-160E Part #: CZ01341
IK05 STK394-160E Part #: CZ01341
Oct 07, 2010 | Televison & Video
I had a convergence problem on my JVC AV-48WP30, and followed the instructions posted by SD Tech. I used STK-392-150 chips and I replaced 1 burned out resistor that had no bands, but was marked 1.8 ohm J...
Yes, it does not happen often but you may have installed or got a new chip that is bad--you did apply heat sink compound to the new chips?
Check all the resistors carefully when you do this and double check all the soldering you do.
Let me know if you need help.
Rate this solution as I DO THIS HERE FOR FREE.
SD TECH
Nov 09, 2009 | JVC AV-48WP30 48" Rear Projection...
I just replaced the convergence board on my JVC AV-56WP74, but the red still won't line up. Are there other parts that should be changed?
you also need to check and replace low value resistors in that circiut.they are all 1 watt,usually they get discolored when stressed.R842 2.2 ohm,R854 and R846 1.5 ohm,R850 2.2 ohm,R858 3.3 ohm,R862 1.8 ohm.they must be the exact value available in MD from surburban electronics.please note stk392-110 upgrade to stk392-150 for future referance.ONCE AGAIN CHECK ALL LOW VALUE RESISTORS
Sep 18, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC AV-48WP74 BLUE CONVERGENCE ADJUSTMENT PROBLEM
Make sure you bought genuine Sanyo chips...if not goto www.TvRepairKits.com and get theirs.
Aug 05, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
http://servicemanuals.vstore.ca/
Aug 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc av48wp74 horizontal convergence unadjustable after after repair
you have to lift one side of the resistor from circuit in order to measure resistance otherwise a open resistor will not read open as you will be reading the resistance from the surrounding circuit. Always lift one side of a resistor out of circuit when testing with a ohms meter.
Jun 06, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP34 convergence issue
Chances are there are other resistors open
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
