Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Dark blotches behind the screen
Just recently, I've noticed several dark blotches of varying color on the screen. It's literally all over the screen when I'm watching TV. I'm thinking that it's just dirty behind the screen, and if I was able to remove the screen I could clean it. Can someone please tell me how to remove the screen on this TV? Thank you.
  • MrSifter Jan 28, 2008
    Well, I did exactly as you said, and the blotches are still there. It didn't help at all. Thanks for posting, though. Any other suggestions? Is it possible I may have to remove the entire screen and clean behind there? If so, could someone please post step by step instructions on how to do so? I'd be so grateful. Thank you!
  • hoss741069 Feb 27, 2008
    We have the same problem and the picture is very dark we have to keep lighting low. We have had the screen off and cleaned it that is not the problem. We were told by a tv repair man that the light engine needs to be replaced for $1,000.00. Now this is our second tv, we had another that developed the same problem and it was taken out and cleaned and it was better but they did not get all of it and my husband wanted a new tv, but low and behold we have the same problem.So what I think is that the light engine has smoke film and dust on it, we are smokers. It is now out of warranty, so if anyone can tell us how to take it apart to reach the light engine we would greatly appreciate it. Thanks Laurie
Sorry MrSifter, I have never tried to remove the screen.
Posted on Jan 28, 2008
When I had this problem with my 52525 I cleaned the bulb with a lint free cloth. The dark blotches went away.
Posted on Jan 26, 2008
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Pixels aren't refreshing correctly in upper right hand side of screen
You might have a Service Co. come out and look at it. It sounds like the Z module is not doing it's job of erasing all prior images after a scene change. Some models there are adjustments for that internally. ( only for a tech ) Start a paper trail now.
Apr 28, 2009 | Televison & Video
Maytag Washer - Discoloration on Clothes
hi, i think your stains are grease from a failing drum bearing, it is a common problem, the bearing needs to be changed, hope this helps, thanks for using fixya
Feb 15, 2009 | Washing Machines
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
Blotches on screen.
suspect the optical engine. are they present after initial turn off before the blinking light comes on and the cooling process starts? if so then it will be optical engine issue. can be very pricey by the way
Mar 19, 2008 | Mitsubishi Diamond WD-65831 65" Projection...
Dark blotches / Dirty behind screen
it could be dust in the mirror or in the optics,in this set if im not mistaken you have acces to the mirror from the back, anywhere from 12-20 screws it sould be easy to remove plastic cover first and the the mirror.this mirror are very delicate you dont want to leave fingr prints on it it will show just like the dust is showing right know. taking the mirror off will also give acces to the lense.
use someting soft to clean it.
hdtvman.
Dec 28, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
490 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
