Question about Microsoft Xbox 360 Console
Xbox and screen
There are little blocks everywhere on my screen. They only appear though on my players and in my dashboard most everything else is ok unless looked at from far away. How do I get these blocks off? It's starting to become more annoying.
  • 121 Answers
Depends what t.v. your using try posting another thread there maybe you will get better results.
Heres some things i can think of
try playing through channel 3 instead of 4 or vice versa, try playing on video or input mode. if your using a cable adapter try tilting it or screwing it on tighter.
Posted on Jan 13, 2008
I have a 320gb hard drive for my Xbox and when it is inserted it doesn't show on the dashboard for memory devises
In this process your hard drive will be formatted, so back up all files to another hard drive, laptop, or be prepared to lose everything on your hard drive. After you have backed everything up, plug your hard drive into an Xbox 360 then go 'My Xbox/System Settings/Memory.Select 'USB Storage Device/Configure Now' then accept the warning.After the formatting is complete a Performance Warning box will appear, click 'OK.' Now in the 'Storage Devices' screen you should see a new option 'Memory Unit.' This shows that the formatting was successful. Disconnect your hard drive, then connect it to your laptop, load on some media (makes sure the file types are compatible), then reconnect it to your Xbox 360. Your selected media should not appear under 'Portable Device' in the Video/Music/Picture Library.
Dec 27, 2013 | Microsoft Open Box Xbox 360 320gb Hard...
My problem is with Adobe Flash Player,or Directv Everywhere Player.I have a year old Gateway NE56R10u laptop.At first,Directv Everywhere worked pretty dam good,but now,when I attempt to go fullscreen with...
Probably won't help but it's all I can come up with.
Default zoom is Ctrl + 0 (zero), though I think that would apply to everything not just one program.
Oct 28, 2013 | Gateway Computers & Internet
Everything on the screen is GREEN. Whats wrong?
Sorry buy you have the green screen of death, sometimes this fault also appears with with a red section in the player 4 LED, as well as as an error code (e74). Check to see if your xbox is under warranty and microsoft should be able help. Good Luck.
Nov 19, 2009 | Microsoft Xbox 360 Console
Black screen with dots but everything is fine.
this is your TV Set. it needs to be bigger and more HD than the one your using.
Sep 06, 2009 | Microsoft Xbox 360 Console
Graphic problems with games
This can mean that the artifacts are problems with the lead free solder and in my experience it will get
worse, its usually on games that require heavy graphics then its definately the lead free solder problem and
will lead to either 3rrod, e73 or e74 etc etc.
my advice is dont play it to death, keep it cool and if you want it to be ok i would do the x-clamp
replacement and possibly re-solder the whole board. this is done by the use of an IR oven similar to what we
use, OR you can use a normal heatgun but i dont recommend it because it can cause damage and knock fuses off
the mainboard if not used properly.
in the meantime id play it for an hour a time and make sure its not in any cupboard or anything. getting
something like an intercooler can help. We use something called SystemX which cures this type of problem.
See how you go.
Jul 18, 2009 | Microsoft Xbox 360 Console
Same problem, hadn't used the 360 for around a week or so, pressed the button on the joy pad, 360 turned on but looked like the controller wasn't sync`d... pressing the sync buttons made the ring lights...
Ok this might help do you have any other wireless thing around you 360 that are on or constanly syncing this could be your problem try turning everything off and just leaving your 360 on then resync the console with the joy pad
May 07, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Cant remember parental control code.
All Details Below On How To.
Turn off your 360 Unit
Remove all memory devices
restart 360 Unit
go to system blade > Console Settings > System Info
left trigger, right trigger, x, y, left bumper, right bumper, up, left bumper, left bumper, x.
This should bring up a menu
Reset System Settings
Resetting your system settings
will return all console settings to
factory defaults. Do you want to
reset to factory defaults?
Yes, reset settings
No, don't reset settings
select to reset settings
your screen should go blank for about 2 seconds
then the language blade should appear that lists several different languages,
select your preferred language
then a blade that says "Xbox 360 Storage Device" should appear
With the options of,
Continue without one
select to Continue without a profile
Then an Initial Setup Complete screen should appear
with the options of,
Family Settings
High Definition Settings
Xbox Dashboard
select Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on.
No more Parental Control lock.
Jun 25, 2008 | Microsoft Xbox Console
Xbox Dashboard on high definition TV
With the latest update to the Xbox Dashboard available from Xbox Live®, you can change the default display mode of the Xbox Dashboard from 480i to 480p. Connect your console to the component inputs of a 480p-capable TV using an Xbox High Definition AV Pack toview the Xbox Dashboard in high definition. To get the latest Xbox Dashboard Using a Broadband connection and the Ethernet connector on the back of the console, connect your Xbox to the Xbox Live servers. When you do so, the latest version of Xbox Live, including the Xbox Dashboard, automatically downloads. You do not need to subscribe to Xbox Live for this update to automatically download to your Xbox. But if you don't have an Xbox Live account, get one! To set the Xbox Dashboard to 480p Connect your Xbox console to the component inputs of a TV that supports 480p with an Xbox High Definition AV Pack. Start the Xbox console without a disc in the tray to run the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Livearea rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twiceto return to the Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select Yes to confirm that your TV supports 480p. Pull and hold both the left and right triggers. While holding the triggers, click (press in) the left and right thumbsticks. After a brief blank screen, the Xbox Dashboard will display in 480p. If you want to return to 480i, repeat the controller combination in step 7, or switch your Xbox High Definition AV Pack with another type of AV pack. Note The opening Xbox animation does not display in 480p, only 480i. To resetthe Xbox Dashboard to 480i Start the Xbox console without a disc in the tray torun the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Live area rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twice to return tothe Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select No to indicate that your TV does not support 480p to reset your Xbox Dashboard to 480i. If your screen appears blank or scrambled If your Xbox Dashboard does not display correctly while in 480p, it might be difficult to see the menus to reset your display to 480i. Connect your Xbox High Definition AV Pack?s green color-coded video output jack (the one marked with the letter Y) to the composite video input of your TV. Note The composite input on a TV is normally color-coded with yellow. Proceed to reset your display to 480i as described above
Nov 20, 2005 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
