Question about Hamilton Beach 40714 Espresso Machine
No power Machine was working perfectly this morning then I went for my noon cup and the machine was off and would not turn off. I checked the power from the plug and there is power. Is there a fuse on this machine?
  • Gobbler Dec 30, 2007
    Does anyone monitor this site or is it simply method to funnel you to the paid experts?
    Problem Solver:
  • 18 Answers
I had mine apart some time ago. I do not recall a replaceable fuse. The unit does have a thermal fuse that will burn out if the machine overheats such as catching fire. To get to the working parts you need to UNPLUG THE MACHINE remove the top. It is a bear to pry off, but it will eventually come free.
Once the top is off, locate the thermal fuse. It should look like a small cylinder, silver or gold, with one pointed end and silver leads coming from each end. Could be near a switch or near where the cord come into the unit. Double check the machine is unplugged for the next step.
Using a continuity test meter, check that the fuse is not blown by placing one meter lead on each side of the fuse. - If you get the top off, the folks at radio shack might be willing to help you test the fuse.
If it is bad, they may carry that part in store or can order it for you.
Posted on Jun 11, 2009
Will not power on
Has thus happened before? If it hasn't, then maybe you've used it like that everyday making two cups and maybe if it needs batteries or other things like that, you could replace it. But, if it doesn't work, you could always buy a new one.
Nov 28, 2013 | Saeco Vienna De Luxe Espresso Machine
I can't get any power to turn on my B60. I checked the plug and gfi and they have no problems. The machine worked fine a few days ago - I went to make a cup this a.m. and it just has now power.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 25, 2011 | Keurig B60 Coffee Maker
I purchased a model B60 Keurig coffee maker in Dec. of 2010. When I went to make a cup this morning 8/21/11 and the coffee maker was off. The power button did not work. I changed outlets and it still did...
heatman101
Aug 21, 2011 | Keurig B60 Coffee Maker
The machine was working perfect. This morning there was no power light on and nothing is working. Checked the plug and it works with other appliance. .
heatman101
Jul 14, 2011 | Keurig Elite B40 Coffee Maker
My Nesspresso machine is a U.S. Version machine and uses 120VAC 60 hertz power input, and it is used on a private aircraft using a 120 VAC 60 hertz power converter. When plugged in an turned on the small...
I don't know if you already solved the problem, but did you check what the maximum output power of your aircraft is? The nespresso machine needs about 1250 Watts, which is a lot of power. A vacuum cleaner or microwave use less power than that (maybe between 800 - 1000 Watts). Maybe that difference is the reason. Also, you mentioned that you converted from 220V 50Hz to 120V 60Hz. I think you only converted the voltage, a frequency converter would cost thousands of dollars.
Jan 18, 2011 | Nespresso Citizmilk C120
How do I set the current time on the 12 cup programmable coffee maker. The hours unit only goes form 0, 1, 2 then skips to 12 thru 19 and back to 0.
I suggest programming it during those hours.
between midnight to 3 am or noon through 8pm.
sometimes it is easier to go with what works instead of asking for it to work perfectly.
Dec 28, 2009 | Black & Decker 12-Cup Programmable...
What are the different settings on coffee machine power knob for?
On other machines with the position switches, 2 turns on the whole machine (elements heatup and groups work). Position 1 turns on only the groups but the machine never heats up. I have never worked on an azkoyen, but the test switch could be for the the board and the autofill circuits, instead of the technician turning the machine to 1 to test those functions, they provided a test position on the switch.
May 21, 2009 | Coffee Makers & Espresso Machines
Brand New Nespresso Essenza just stopped working..
If you just bought it you should return it immediately and try another.
Dec 24, 2008 | Nespresso Aeroccino Automatic Milk Frother
Rinsing cycle won't START
After all, I turned machine off with power switch, waited 30 seconds and turned it back on. It displayed "RINSING CYCLE" message, but this time went through regular rinsing cycle, then rinsed thoroughly (I counted several cups of water) and RETURNED TO NORMAL.
Halleluiah! Now I can get my morning coffee again!
Aug 30, 2008 | Gaggia Titanium Espresso Machine
Too little coffee
reset to factory default...
1. Power switch off
2. Press & hold coffee cup button while powering back ON
Mar 22, 2008 | Nespresso Essenza C100 Espresso...
Hamilton Beach 40714 Espresso Machine Logo
222 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Marvin
Marvin
80stech
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
