Problem HP Compaq nx 7300 Hello.I got a problem with this pc.When i push to start nothing happen...only the battery light blinking 8 times yellow.The power plug is in and the battery to. When i take out the battery is no blinking lights. What is the problem? I removed the memory and took it back.Removed the harddrive and back again ....push the start button 20 seconds...nothing changed... Plz need help...Thank you
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Comments:
Oct 23, 2009
- That's excellent news! Thanks for the update. Congratulations on your success. I love my NX7300.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
I repclaced the charger...no is ok again...thx for the help :-)
" - clokker
Popular Solutions for HP Compaq nx7300 PC Notebook
L35-S2171, Monitor screen will not light up. Screen is new, inverter is new. I can see images when I...
(More)
L35-S2171, Monitor screen will not light up. Screen is new, inverter is new. I can see images when I shine a flashlight on the screen. The rest of the computer works just fine. What is the fix for this problem?
fills all text bars with $ For example, in the search bar, it will fill up the seach bar with...
(More)
fills all text bars with $ For example, in the search bar, it will fill up the seach bar with $$$$$$$$$$ until it overruns and starts beeping
Hi, I have Hp Compaq nx 7300 with windows Prefession server pack 2. in Bios setting i Select dafault...
(More)
Hi, I have Hp Compaq nx 7300 with windows Prefession server pack 2. in Bios setting i Select dafault setting after that my windows not working in safe mode, normal mode, dos mode and previous setting. when i select any option like safe mode or normal start after 1 minuts same options again comes. And not booting up from CD what should i do.
my compaq nx7300 doesn't recognize Alesis io 14 soundcard partialy, i.e. it is recognized- and...
(More)
my compaq nx7300 doesn't recognize Alesis io 14 soundcard partialy, i.e. it is recognized- and working ok- by Cubase or other stand-alone VST's, but not by the WinMedia player.What can i do? Thank you in advance, Nik
hello,my hp nx7300 is running very slowly;it takes more than an hour to install os.Would you please...
(More)
hello,my hp nx7300 is running very slowly;it takes more than an hour to install os.Would you please tell me somethiong about it thank you!
