If your dehumidifier run for shrter time and if cuts off often and the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting.
If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit.
If that doesn't work, sounds like you may have a rusted evaporator coil and that has caused a freon leak.it is very common on newer units as they are not made as well as they used to be.when the coil rusts, it will cause the freon copper lines to leak the freon out and then without enough freon it will usually freeze over a few coils and eventually not take any water out of the air.
i would check to see if yours has an extended warranty and then contact the manufacturer to see if they can fix or replace the unit
Please leave me comment , if you need further assistance
Rnj VINODKUMAR
Was this helpful?
Yes
No
Popular Solutions for Maytag M7DH65B2A Dehumidifier
Maytag M7DH65B2A. Water goes onto the floor instead of into the bucket. This dehumidifier worked...
(More)
Maytag M7DH65B2A. Water goes onto the floor instead of into the bucket. This dehumidifier worked well in the past.
